Clutch Gurus Inside pls
The tilton twin disc I have comes with the hrb (hydraulic release bearing) which says only dot3/4 however the native master uses CHF202
Titan sold me a tilton flywheel twin clutch kit but did not provide a master cylinder, so I assumed (like a retard) that this was compatible with the native system. A few days later, swollen seals, blown hrb using CHF202
Can someone please tell me where I can find a dot 3/4 compatible master cylinder so I can actually drive my damn car???
Thank you in advance.
I just did the gt2 slave conversion and love it.
Although I'm not familiar with the hydraulic realese bearing.
Do you even need a slave cylinder and fork?
I did gt2 mc, pedal spring since I didn't have one, had a line made at a hydraulic shop for about 30 dollars.
Isn't the tilton setup a "push" not a pull setup, with the throw out bearing/hydraulic clutch on the gearbox input shaft like the cup cars use??
Gt2 or 3 mc should work.
Pedal feel is identical to the gt2 pressure, just less stuff to mess with when going in-out. My trans was out in 30 minutes compared to before.
99642317106 gt2 master cylinder
99342341700 dot 4 container. you might want this as well if your using the factory master cylinder reservoir for the new dot 4 fluid. you can flush the one you have and just get the cap. my cap was a 4 week backorder!!
Apparently it was stock on the GT2, shouldn't be an issue as it's OEM.
Factory GT2 master will do the job with dot 4 brake fluid.
#TeamAIM
#TeamAIM
jaehoppa
Oct 22, 2015 09:17 PM
PelicanParts.com
997 Vendor Classifieds
Sep 11, 2015 02:39 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
