Gtx2867
Yes you are right, a few months ago was looking for specs regarding the gtx29 series, not too much out there.. just saw the 2967 @garrett site. I guess the 2971 might be ok, the gt29 turbine comes with two wheel options, imo this turbo will be much better than any alpha30
FWIW I still think that the sweet spot for a stock 3.6L motor is a gt28 (or equivalent, K16, EFR6258, TD05H, etc) sized turbine wheel with a suitably-matched billet comp wheel if response is an overriding concern..
I was thinking 3076 at even 1.3 bars would give an easy 600 whp on something like E30 gas
In freezing cold the car does over 600 whp on E70 gas but recently with temps at 65-70F power is way down which is weird because last year in 85F it was doing implied 600 whp but I am at absolute max for the K24s.
Expect 3076 to spool like 400+ rpms later than K24
After having 3 turbo setups on my car and looking for the 4th, I would say if you dont plan for 800whp than dont go with 3076, pick the smallest turbo that accomplishes your targets. My guess is a hybrid K24 will be the best way to go if you look price/performance and gt28 or efr62/6758 if not taking into consideration price for upgrade.
My plan and you can help me with the thinking is this is that I can run larger turbos with great fueling at lower boost. My poor old K24s now on E85 hit 1.5 bars which is a wee bit much
so
1. A3076s
2. Run an E85 tune at about 1.3 bars
I am MAFLESS with excellent ETS Intercoolers rated up to about 1000 bhp
That will give me a car in the region 770-800 bhp ???? and 5.8s 60-103 mph
Mafless and E85 will help me spool much quicker than otherwise by about 500-550 rpms or so but as this is on a stock block I do not want A28 type spool as the few A28 cars I have been in have scared the bejesus outta me
The plan is to do rods and minor engine stuff next year and run higher power to do the Tx Mile
@1.35bar 93octane timing I was able to get 6.0s 100-200hmh or like 6.5ish 60-130mph, I expect E85 to lower that by .2-.3s or so, I would guess you need at least 1.5bar to get 5.x 60-130.
I dont have a dyno of my A3076 setup, but now I run a bit bigger turbos gt30s based though, 1.3bar did 660whp, 1.65-1.7bar did 800whp or a bit more, this done with meth and racegas timing
I have never run E85, but spooling 500-550rpms earlier seems too much to be true..
If you plan for rods take A28 into consideration, otherwise A3076 are the best step to do
You have to run 1.5bar+ to wake up A3076, otherwise isnt worth it... on stock rods you can run 1.5bar for a while, maybe limit torque a bit or use 93octane timing on a E85 tune and I guess you can run for a long time
My MAFLESS and E85 runs 550 rpm quicker than the stock K24s, that is across about 100 measured runs but I am measuring from insta boost not peak boost so you may be correct but even MAFLESS made them spool quicker.
If I run E85 at lower boost will that give the added oomph on 3076s... I see that Spoolbus pushed 690 awhp on alpha 3076 with meth inj and 93 octane on 1.5 bars.. so I guess 1.3 bars on E85 will give mid 6xx whp
I guess so... 650hp is what they should be good for at 1.3bar, also the above times of my car 100-200 and 60-130 were stock weight, 4wd,0% decline, no break boost, no flat shift, etc... So if you use all the tricks in the book maybe you will see a 5.x 60-130
TY that is what I was looking at
This is good to hear! My 5431's are a tad smaller on the inducer side than the 3076r's and I'll also be on E85. I'm Hoping to be in the 6xx whp on 1.3-1.5 bar. What RPM were you seeing the K24s come on? I do not remember any discernible 'lag' with the smaller k16s at all.
So final choices are the following
gtx2867
gtx2871
gtx2971
Let's take them one by one
1. gtx2867 - 48lbs capable compressor wheel, so should be good for 800whp on a 996tt, I would do the small A/R to have better spool as the compressor wheel shouldnt maximize the turbine
Anyway housing choices are:
Turbine Housing Options
PN A/R Type Divided Housing Inlet Outlet
430609-230 0.64 Wastegated N T25 5-Bolt
430609-231 0.86 Wastegated Y T25 5-Bolt
827690-1 0.57 Free Float N V-Band V Band
827690-2 0.72 Free Float N V-Band V Band
I guess the 0.72 V-Band is the way to go, giving both good spool and decent high end. I would say this should be the best turbo for a daily/street 996tt on stock displacement
2. gtx2871 - 56lbs wheel, for sure a bigger A/R is needed as the turbine wheel is huge, I would do it with smaller A/R first and if will still miss more power, might switch only turbine housing to a bigger one. Also TIAL housing is available ! Would do it with either 3.8L or 3.6+heads work to increase red line so they should provide enough power band.
3. gtx2971 - same 56lbs, bigger turbine wheel (old gt3071 turbine). Only for high boost lovers and guys looking for every HP. Guess will spool really fine with a 3.8+ liter and higher red line
I would exclude the gtx2971 as will have another car to be build with gtx3076, also I will eliminate the bigger A/R options, so will stick to 0.64 or 0.72 A/R with either wheel 67 or 71. I would match the bigger wheel to the bigger housing so the options would be
Gtx2867 A/R 0.64 or 0.72, externally gated - 480 hp rated
Gtx2871 A/R 0.64 or 0.72, externally gates - 560 hp rated
I guess the 2871 will loose 4-500rpms (combined form bigger comp wheel and bigger A/R) in spool and hit but should deliver 100hp more up on top and still being very enjoyable on the street and raceway at lower boost.
By the other hand I would have no problem to stay bellow 800hp on the 2867... problem is I can not estimate what the difference would be between the two options.
Any inputs you gt28 guys?
gtx2867
gtx2871
gtx2971
Tial Alpha28's 3.8L
Here is what I did with my Alpha 28's (GT2871) on both stock motor and built 3.8L. Car leaned out cause I was running out of fuel. 29+PSI
Stock dyno is at 26 PSI, and a more aggressive dyno (Dyno Dynamics)
