Valentine One Question (and EZ PASS )
Old Nov 2, 2005 | 07:28 AM
SHANKENFELTER's Avatar
SHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud ofSHANKENFELTER has much to be proud of
I picked up the new 750Li and the windshield is coated with some heat resistant /reflective layer. My I-Pass doesn't seam to work at all, and neither does my V1.
Does Valentine have a setup where the sensors are outside somewhere? ANyone here have this?
ALso, anyone mount the IPass in their hood or somewhere else that will pick up the signal?
Old Nov 2, 2005 | 07:50 AM
Vik's Avatar
Vik
Vik has a spectacular aura aboutVik has a spectacular aura about
For the I-Pass:
You can purchase a license plate tag transponder if your windshield has a coating, but it needs to be mounted to the front plate (which you probably don't want to do). Maybe you can place it somewhere else on the car. Here are the instructions at the bottom:
http://www.illinoistollway.com/porta..._schema=PORTAL
For the radar detector:
I believe there is a small square cut out in the windshield coating at the very bottom and center of the windshield, where you can mount the radar detector.
Old Nov 2, 2005 | 07:51 AM
DEETZ's Avatar
GO 6SPEED!
DEETZ is infamous around these parts
Solution #1 = Ask Mike
Solution #2 = Roll down the window, stick your hand with the EZ Pass
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
the bumper mount sunpass units will work inside the bumper. i had one for a long time before they switched to the interior version.
Old Nov 2, 2005 | 07:53 AM
Shank:
Do you still own all of those cars on that list? Where do you keep them all?
Old Nov 2, 2005 | 08:36 AM
bdrl720's Avatar
bdrl720 is infamous around these parts
^ Yes Shank owns all those cars currently !
Shank,
I had a similar problem on my car, and i had the dealer mount the Ipass under my hood by the front grill somewhere. It always works now ! My MB dealer did it for free too !
~Ash
Old Nov 2, 2005 | 08:40 AM
be careful as i'm not sure the window mount models are weather proof. three failure to pays in FL and then they start mailing you tickets.
Old Nov 2, 2005 | 09:38 AM
RaDaRkInG's Avatar
RaDaRkInG is infamous around these parts
Re: Valentine One Question (and EZ PASS )
You can get a V1 remote kit from here for $795.00:
http://www.radarjammertechnology.com...ne-1/index.php
It moves the sensors to the outside of the vehicle in waterproof cases.
Old Nov 2, 2005 | 11:26 AM
93 r1's Avatar
93 r1 is infamous around these parts
There is usually an area of the windshield that isn't covered with the material, just for this reason.
Old Nov 2, 2005 | 12:13 PM
Gator Smiles's Avatar
Gator Smiles is infamous around these parts
My mom's 745 has the same coating and we found the same issues with V1. Get the car in sunlight and look from the outside up toward the rearview. there is a "window" of filmless area where the V1 should be located. I believe there is also one on the lower edge of the windshield as well, just can't remember exactly where. I searched on a bimmer forum about this when mounting hers. Can't remember the site though. Great looking 7--love the 21s.
Old Nov 2, 2005 | 02:51 PM
Arnie's Avatar
Arnie is infamous around these parts
In Nj they have license plate mount for EZ pass which I use
Old Nov 2, 2005 | 04:00 PM
Alex13188's Avatar
Alex13188 is infamous around these parts
If you look on the windsheild by the rear view mirror you can see where you can put the EZ PASS they leave the film off on ethier side of the mirror. At least that is the way it is on my dads 745.
Old Nov 2, 2005 | 05:28 PM
Sharif's Avatar
Sharif is infamous around these parts
Hey Shank,
I got the license plate ez pass and put it under the hood, works perfectly. As for the V1 detector, there is a cut out between the two humps on the dash.
Old Nov 2, 2005 | 05:29 PM
Sharif's Avatar
Put eZ pass here
Old Nov 2, 2005 | 05:33 PM
Sharif's Avatar
here's where I put the V1, look carefully there is a cut out there.
