DIY Urethane engine mounts
Old Apr 21, 2015 | 04:01 PM
DaveSen's Avatar
DaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud ofDaveSen has much to be proud of
Does anyone have DIY information on converting OEM engine mounts? I see at least one company does this conversion. It sounds like it involves removal of the fluid, clean, and fill with 80-90 durometer A urethane.
Wondering if anyone can share a process and material?
Old Apr 21, 2015 | 06:39 PM
32krazy!'s Avatar
did this type of stuff on my mercedes. basically drilled the mount and drain the fluid. clean with thinner and dry. using window weld squeeze into the mount until its full. takes a couple days to fully cure and reinstall.
if you search the trans mount threads theres also threads doing the trans mount with window weld. any home depot has it in the caulking aisle
Old Apr 21, 2015 | 07:03 PM
su_maverick's Avatar
su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !
How is it with vibration/noise? I was thinking about poly mounts but saw in the other thread that it hurts driveability.
Old Apr 21, 2015 | 07:38 PM
32krazy!'s Avatar
3" exhaust no cats straight cut gears and tial turbos with bov's. not real concerned with nvh! LOL
i have window weld trans mount and torque solutions motor mounts. no added nvh that i can tell. again my car is loud
Old Apr 22, 2015 | 12:16 PM
DaveSen's Avatar
Mounts
Thanks 32krazy for the comments..
I did find another post where someone had successfully filled the OEM units, and also indicated good results over the next few months of driving. They did not specify what compound was used or any difficulties.
It seems like this would be a very easy DIY and just wondering why more have not tried it to save the $$ for other mods.
Old Apr 22, 2015 | 06:43 PM
32krazy!'s Avatar
most w/w is 74 durometer. i use the torque solutions mainly because i needed the lower profile of the mounts for my larger y pipe.
Old Apr 23, 2015 | 02:15 PM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
Might be able to get some help in our tech forums.
-Luccia
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old Apr 23, 2015 | 07:43 PM
32krazy!'s Avatar
i think i have a set of engine mounts if you want to experiment. pay shipping they are yours (if i can find them!)
Money2536
Jan 19, 2022 08:22 AM
Jul 29, 2019 11:13 AM
nlakind
Nov 6, 2015 10:15 AM
Lucid Moment
Aug 20, 2015 02:22 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
