Alpha 3076, E85 tune, Stock Engine
Used a simple formula
Pauter rods
Raceware studs
Cometic headgasket
Did also very light polish job on heads
This is all...
Maybe would add some light valvetrain mods and cams for big turbo setups, but I am going smaller turbo... Lol
Pauter rods
Raceware studs
Cometic headgasket
This is all...
My advise to get Carillo Rods instead of pauter , not because pauter is bad ... Puater rated to 1000hp , carillo is way more !
Now am rebuilding my engine again because I can not go more than 2.0bar 35s turbos .. Afraid of the Rods damage !
So do it one time
and you will be safe
So do it one time
Carrillo rods, swap the oil pump for clearance, good headstuds. That's my eventual plan, don't even want to crack the halves. I could be convinced to do sleeves maybe but then I might want more displacement
KISS!
KISS!
pauter rods require no oil pump cleanse.
carrillo rods are said to be stronger in the weak areas ( cap and bolt areas) but require oil pump clearancing unless you use a 4.0 pump
racewear headbolts are the ones to use . can't say why the arp won't hold as they are the choice for dozens of engines. but not for these motors.
raceway headbolts require 2 complete heat cycles and a RETORQUE. this means the motor has to come back out and the cams removed to do this. more $$$
while the motor is out have the cylinders oringed. also have the builder do some light head work. nothing crazy just clean them up. same for the headers.
if you have the cash install the gt2 manifolds. made of metal and holds higher boost
you have one of the best engine builders in the world already working on your car. get with him and follow his advice. he won't steer you wrong.
now remember once the motor is built and you have a 1000 hp monster the axles and trans won't last for long. so plan on another 10k$ to address this.
I would point out that at least one builder has found a way around the need to R&R the engine after running it for a retorque.
SRM built a hotbox capable of heating the engine to full temp, did so, and then retorqued the headbolts! Seems damned smart to me. Is there any reason not to run the 4.0 oil pump? Could the existing oil pump be pulled, clearanced, and put back in? Frankly I'm wanting to do as little as possible on a well built well running engine to get it back on the road when that day comes
yeah, trouble is everyone from Long Island goes there as well
yeah I hear you... my plan is the following and maybe everyone can correct my thinking....
NB The missus freaks when she sees my car bills so I have been drip feeding $5-$6k here and there into it... also gives me time to get used to the power and mods.
So far I have gone from an old GIAC tune and AWE GT2 exhaust at 520 bhp or so to an upgraded fueling system, Eurodyne tune = 570 bhp or so, to RWD, to MAFLESS and E85 so my 60 to 130 times have gone from 8.8s - 8.3s - 7.8s - 7.2s or so now down to 6.50 s (very cold temps) and corners I used to take on old Potenzas at 52 mph I can now take at 60 mph on R888s.
So choices now
A
1. TIAL Alpha 3076r
2. EBC
3. 1400 cc E85 injectors (I have ID1000 now)
4. E85 tune at 1.4 bars ramped from 1 bar in peak torque area to 1.4 bar above 5000 rpm
or
4a. 93 octane tune running rich so I can use E30 fuel and keep ID1000s and not worry so much about the torque limits
or
B
Mild engine build and keep current set up until after summer
1. Carillo rods
2. Racewear headstud and bolts
3. ID 1400cc
Then when I am used to the new set up add the turbos and turn that boost up
So choices now
A
1. TIAL Alpha 3076r
2. EBC
or
or
B
1. Carillo rods
3. ID 1400cc
