Boost pressure / CAN question
Old Jun 1, 2015 | 06:54 PM
pwdrhound's Avatar
Anyone know if the dash gets it's displayed boost pressure value from the CAN bus or is it a standalone display directly from the sensor like the oil pressure gauge in the dash?
Anyone have a full list of the values that are available on the CAN bus on the 996TT/GT2?
Old Jun 1, 2015 | 11:09 PM
BLKMGK's Avatar
CAN is what I've been told, pretty much everything on the dashboard is CAN data if what I've been told is accurate - that includes the gas gauge and boost gauge. With a standalone you can read higher than the stock pressure sensor for instance and the weird behavior with filling the gas with a 1/4 tank and key on can be fixed supposedly. I've never asked about the oil gauge but had thought it was CAN as well?
Old Jun 1, 2015 | 11:52 PM
pwdrhound's Avatar
I'll check with the guys at my shop. We are going to be putting in a Motec and I was just wondering what all we'll be able to pull off of CAN. For some reason I wanna say that my understanding was that oil pressure was strangely enough not one of the items on CAN. I figured maybe someone had a list of all the items..
Old Jun 2, 2015 | 06:13 AM
jpflip's Avatar
From the sensor (pressure/temp) to the DME (ECU) it is dedicated wiring....But from the DME to the instrument cluster it should be part of the can drive bus....
Name:	Screen Shot 2015-06-01 at 21.47.36.jpeg
Old Jun 2, 2015 | 06:15 AM
jpflip's Avatar
Here are the cluster connections:
Name:	Screen Shot 2015-06-02 at 08.08.40.jpeg
ID:	421380   Click image for larger version
Name:	Screen Shot 2015-06-02 at 08.08.50.jpeg
Old Jun 2, 2015 | 06:24 AM
jpflip's Avatar
In fact oil pressure transmitter is connected directly to the instrument cluster: Look at the troubleshooting if you got the code 9121: Plug B pin 5...
Old Jun 2, 2015 | 06:56 AM
jpflip's Avatar
It is only a deduction since I don't have access to all the data going through the busses , drive (low/high) comfort (low/high) but on the input data to the instrument cluster there are no mention of pressure/temp so it has to be through the bus connection "can antrieb high or low" antrieb being drive in english..... Comfort is normally related to the air conditioning data....
Name:	Screen Shot 2015-06-02 at 08.52.38.jpeg
Old Jun 2, 2015 | 08:44 AM
pwdrhound's Avatar
Thanks Jp. That confirms it.
Old Jun 2, 2015 | 10:33 PM
BLKMGK's Avatar
Interesting, talking to a contact at AEM I was told the following:
"(the Infinity is directly controlling oil pressure, oil temperature, coolant temperature, engine speed, boost pressure, oil pressure warning light, check engine light, reduced engine power light and plays a role in fuel level). ABS, PSM, and PASM all still work like stock and PSM can still be disabled."
I would assume that ProEFI andSyveccs would have to do the same for a properly operating dashboard. The wiring doesn't lie though but you still may find oil pressure and temp data on the CAN bus it seems.
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
PelicanParts.com
Aug 26, 2015 04:25 PM
PelicanParts.com
Aug 26, 2015 04:24 PM
