Does this sound like a Rod gone ?
Old Jun 10, 2015 | 08:22 PM
wolfhedge's Avatar
wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !wolfhedge Is a GOD !
I found a minor boost leak yesterday where I had tugged at a hose a bit too aggressively, fixed it, topped up my cooler fluid a teensy bit, topped up my oil and suddenly found my lost 100 hp....
I beat on the car today and it ran perfectly, did 6.5s 60 to 130 mph in 85F temps...... then tonight I was going to listen to some music and went to take the car out.....
At idle it sounded like ****..... I drove on low power for a warm up and then did some videos where it still sounds like ****.
Does this sound like bent rods ?
warm idle
hot idle
Car is going in next week to Tim anyway !
cold idle
Old Jun 10, 2015 | 10:02 PM
BLKMGK's Avatar
Uh boy, sounds like something is rubbing for sure! Checked the filter or drain magnet (if you've got one)? Any chance it's a turbo? Seems to be a pretty fast repetition to me for the RPMs but if it's rubbing on something inside it would be on intake and exhaust strokes. Guess this helps you decide next steps, sorry to hear!
Old Jun 10, 2015 | 10:29 PM
John@SpeedTech's Avatar
Could be an intermediate shaft problem - it can sound like that and many other things, too. It's hard to say from the video, but if it's loud and you can tell it's really just not right, then you should immediately stop driving it and start thoroughly diagnosing. If it's not able to be located with the motor in the car, then most likely you will end up taking the motor out and apart to find the issue. And you probably should before much more serious damage occurs. You need a shop that knows these engines very well and has rebuilt them, so they will be able to easily spot and identify anything out of the ordinary.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Jun 11, 2015 | 04:46 AM
mtlsp's Avatar
mtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond repute
not good ,sorry for you Mate if it sound louder from under the car then good chance a rod is knocking !
be careful not to damage to crankshaft and stop running your engine .
good thing now it's time to build your engine and you didint blow her up...
here is mine (rod knocking)
Old Jun 11, 2015 | 05:07 AM
'02996ttx50's Avatar
3 seconds was all i needed. uh oh
Old Jun 11, 2015 | 05:55 AM
ttboost's Avatar
Could just be a failed lifter too...very common in these engines. Engine still has to come out, but a cheaper fix...if that's all you want to do...
Old Jun 11, 2015 | 06:16 AM
wolfhedge's Avatar
Car was going to The Tim next week to have rods, headstuds etc done...... will have to tow her down there.
The E85 at my station was back up from 75% to 84% so the extra power may have done it.
thx for input
Old Jun 11, 2015 | 06:27 AM
wolfhedge's Avatar
I was getting a weird rumble/grumble in 3rd-4th gear on WOT at max torque levels (4000-4400 rpm) just as max boost was reached on and off for a few weeks.. could this be indicative too of IMS failure (ball bearings rattling at high speed ?)
Old Jun 11, 2015 | 06:35 AM
wolfhedge's Avatar
John@speedtech
Yeah I just found some of your old posts at rennlist where you discuss this and osme old videos here.. mine sounds exactly like the IMS failure on this video
Old Jun 11, 2015 | 07:17 AM
NTIMD8's Avatar
NTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond repute
Off topic but what specific hose was it that was loose that robbed you of your power before you fixed it?
warm idle
https://www.youtube.com/watch?v=mH-6gkwgdsk
hot idle
https://www.youtube.com/watch?v=ogr10eYPDx4
cold idle
https://www.youtube.com/watch?v=INBmenOBeAQ
Old Jun 11, 2015 | 08:13 AM
wolfhedge's Avatar
off the bottom of the reservoir at the base was just a teensy bit loose
Old Jun 11, 2015 | 08:25 AM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Sounds like a lifter collapsed
Old Jun 11, 2015 | 09:04 AM
wolfhedge's Avatar
So if I am doing rods n headstuds do I just go to a 997TT lifter ?
Old Jun 11, 2015 | 09:08 AM
NTIMD8's Avatar
Im confused. Your coolant line off the coolant tank was loose and caused a boost leak and loss of 100hp?
Old Jun 11, 2015 | 09:11 AM
VGLNTE1's Avatar
I definitely not the person to ask that. I'm still learning myself.
