coolant hose keeps popping out
Old Jun 12, 2015 | 07:14 PM
crash41301's Avatar
crash41301 is a splendid one to beholdcrash41301 is a splendid one to beholdcrash41301 is a splendid one to beholdcrash41301 is a splendid one to beholdcrash41301 is a splendid one to beholdcrash41301 is a splendid one to beholdcrash41301 is a splendid one to beholdcrash41301 is a splendid one to behold
So I've now tried attaching this hose 3 times. Its a brand new oem porsche 996tt hose.
Each time it's fine when I drive around. I am able to idle it and bleed the system. When I full throttle to red line in gear it is popping out. Any thoughts? I can hear it physically snap in place when I put it in there. I am running out of ideas here...
Old Jun 12, 2015 | 07:47 PM
crash41301's Avatar
Could it be the clip thats worn out? After it cooled off I pulled the hose out of the way, left the clip on and felt with my finger nails. It feels like there is only something catching the hose on one side. The other side is nearly flush. Makes sense it might pop off easily given that fact?
Old Jun 12, 2015 | 08:22 PM
32krazy!'s Avatar
yep replace the clip with new one. also make sure it is fully pushed in. some lube on the oring helps
Old Jun 12, 2015 | 09:48 PM
crash41301's Avatar
I found online that the left and right coolant hose clips were different size. Went outside pulled them off, holy crap yep slightly different sizes. I swapped them and now the right hand side has a good area to latch onto. Wow that's seriously dumb... they are within millimeters of being the same size.
Will find out tommorow if it holds now. Wish me luck!
Old Jun 13, 2015 | 05:15 AM
jpflip's Avatar
I also found that out but luckily trying to pressurized with air after coolant pipes welding...
see post 105: https://www.6speedonline.com/forums/...-needed-7.html
Old Jun 13, 2015 | 08:26 AM
'02996ttx50's Avatar
the c-clips are notorious for losing their ability to clip. replace them all.
Old Jun 13, 2015 | 08:43 AM
03 996tt's Avatar
03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future
swap the clips. When I replaced my coolant hoses, I realized the clips are ever so slightly different in size. one clip fits both sides where the other only fits into one side. In fact. I marked them when I took them off so as not to screw this up. hope it helps.
Old Jun 13, 2015 | 01:49 PM
crash41301's Avatar
Refilled this morning with the clips swapped. Went for a drive, woohoo! It stayed on there. Thanks so much guys. Hopefully in the future someone that runs across this same issue can read this thread and get help too
Old Jun 13, 2015 | 01:55 PM
rmc1148's Avatar
Good to hear!
Old Jun 13, 2015 | 07:48 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
id also replace the clip, if not, hose. - i guess you fixed it . lo
Old Jun 14, 2015 | 08:52 AM
Thumbs up
it's crazy. sometime it is the SMALLEST yet critically important items we never think about, and are most often overlooked that cause us the most consternation ! congrats!
Old Jun 29, 2015 | 11:01 AM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
anyone have a link where to buy these clips? I found a puddle of coolant under my car this morning and think its time to start replacing these.
Old Jun 29, 2015 | 11:06 AM
levinsje's Avatar
levinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to behold
I had the same issue, bought new hose and clip, and the same thing happened. I did not know the right and left side clip were slightly different and the supplier did not inform me. After the second time I installed the new hose, put on the clip, put a high quality hose clamp over the clip to hold pressure (this alone held it on well), did an X-pattern on the hose/alum fitting with plastic covered metal wire. End of problem.
Old Jun 29, 2015 | 11:25 AM
I jokingly say it's the only part I will get from my local dealership even if options exist. even then they are like 5 bucks! for a C CLIP
Old Jun 29, 2015 | 12:22 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
The amount that people say to just buy things here is crazy. Lol
"Ignition switch, maf, and n75 is OK? Better change them".
Lol
