engine down, suggestions?
Old Sep 24, 2015 | 11:54 AM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
My friend's engine just blew, bent rod and broken sleeve, i suppose new aftermarket stronger rods are going in but what can he do about the sleeve?
It doesn't seem like they can be sold from the dealership. Can it come from an other used engine? Is there anything aftermarket?
I don't know anything about these engine internals, please educate me.
Engine has a set of Tial A28 running water meth and 1,4bar, ran well for a lot of time but i guess all this strees took it's toll on it.
thanks
Old Sep 24, 2015 | 12:05 PM
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
I have a set of stock sleeves and pistons for sale if he wants them. Let me know.
Old Sep 24, 2015 | 12:29 PM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
Turbo Engine
There was a guy selling a used 996 Turbo engine in the Marketplace back in September. Don't know if he ever sold it. Do a search on "Turbo Engine."
Old Sep 24, 2015 | 01:57 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
I think that is 32krazy!
Old Sep 24, 2015 | 04:05 PM
32krazy!'s Avatar
it was me. still have it if theres interest. in regards to the sleeves you can do what I'm doing. LAsleeves in steel with steel rings . you can do either 3.6 or 3.8 with pistons if going bigger. rods and head bolts are a must. I'm using the 12mm head studs which require machining to fit but can be torqued to almost 3 times factory specs . I'm done with lifting heads. i also did a gt3 oil pump more as maintenance since the motor had approx 106,000 miles on the pump. it was cheap and the case is open anyway. you need to replace all the bearings, seals and orings as well. freshen the entire motor while its open.
i also know a guy who has a set of sleeves that have 5000 miles on them. perfect shape. can probably get them pretty cheap
or buy mine!
Old Sep 25, 2015 | 05:22 PM
pumalex's Avatar
or buy mine!
do you have a link to the aftermarket sleeves you are talking about? Also, can you give me some details about the 5000 miles used sleeves, is that from you or a friend of yours? send me some details by PM if you can.
thanks
Old Sep 25, 2015 | 08:39 PM
32krazy!'s Avatar
thanks
call sean at silly rabbit motorsports. he can give you all the info on the LA sleeves. sent you a pm with the used liner contact info
Old Sep 27, 2015 | 06:11 AM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Ideal time to go stroker motor.
Old Sep 27, 2015 | 08:58 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
if you cant find any spare parts, ive got alot laying around.
Jul 29, 2019 11:13 AM
richard181
Bentley
Sep 9, 2015 01:53 PM
midwestamv8
Audi
Sep 9, 2015 11:53 AM
vr6tee
Aug 29, 2015 03:52 AM
The Oss
Aug 24, 2015 08:19 PM
