996TT: high-pitched whining sound from the rear
Old Oct 16, 2015 | 10:18 AM
Rick Brooklyn's Avatar
Rick Brooklyn is infamous around these parts
Hello everyone, new member here.
I test drove a 2004 996TT yesterday, and all was great except this high-pitched whining noise, sort of like the whistle of a teapot or a kettle, that I could hear from the back of the car when driving at low RPMs (like when slowing down to a stop sign). Kind of like this sound, but cleaner and at a constant pitch:
The noise was not audible at idle with the car stationary, only when driving at very low speed and low RPMs. The seller said "it's ok, all 996TTs do that".
Clearly I'd like to figure that out before I fork out the cash. The car will go through a PPI next week and I'll ask the shop to focus on that issue, but I was hoping to get some thoughts from your collective wisdom in the meantime.
Old Oct 16, 2015 | 10:30 AM
red330I's Avatar
red330I is infamous around these parts
Does it stop when you engage the clutch? If so, it is most likely the power steering reservoir. It has a faulty valve inside and will whistle when hot.
I believe the part is around $850 and probably a couple hours to replace.
Old Oct 16, 2015 | 10:33 AM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
Don't believe the seller, What I would do, put the car on lift, engine off, throw it in neutral, and spin the rear wheels, could be bad wheel bearings, tranny bearings? check brake pads, what about if you throw in neutral while coming to a stop sign/lights, does the sound change? If you hear only when at low rpm's. its moving part of course. also check condition of the Serpentine/accessory belt, (easy to replace) maybe one of the bearings is making noise. let Mechanic to focus on that issue. Let us know. yes also power steering reservoir can make that noise , check the fluid level.
Old Oct 16, 2015 | 10:35 AM
Thanks - I can't remember if it stopped with the clutch, it might have but not sure. I am positive though that it's coming from the back of the car, is that consistent with the power steering reservoir?
Old Oct 16, 2015 | 10:37 AM
Thanks - it's possible that I could only hear it at low RPMs because it was drowned by engine noise at higher RPMs, but when sitting at idle I couldn't hear it.
Old Oct 16, 2015 | 10:41 AM
MadWhip's Avatar
yep, just get the quote from the mechanic and let seller know how much will it cost to fix it. IF everything else checks out ok, go for it
let us know if you have any other questions and good luck
Old Oct 16, 2015 | 11:32 AM
88mmm's Avatar
88mmm is infamous around these parts88mmm is infamous around these parts
Ah, just get a catless mufflerless exhaust and you won't here it anymore
Old Oct 16, 2015 | 02:29 PM
'02996ttx50's Avatar
Originally Posted by rick brooklyn
The whine is distinctly coming from the rear of the car, if that can help narrow it down...
cross posting. better than cross dressing i'm guessing hah.
do a "google search" on TSB 4897 the infamous power steering reservoir valve overheating = "whine".
https://www.6speedonline.com/forums/...reservoir.html
Old Oct 16, 2015 | 02:57 PM
CBRacerX's Avatar
CBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to beholdCBRacerX is a splendid one to behold
So the gory details on the TSB note that this is a valve in the cover of the reservoir. For $800 I'd be interested in fixing what I already have! Does anyone have a good image of the updated cover valve?
Old Oct 16, 2015 | 04:24 PM
Thanks, it does sound similar to what I was hearing. I see now that there's a ton of material on this issue, I'll read up. Hopefully it doesn't end up being something else like the guy in that thread...
Old Oct 16, 2015 | 06:27 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
power steering reservoir. Mine does it... nothing bad other than the sound.
Old Oct 16, 2015 | 06:49 PM
this is true. never heard of any ancillary issues that result from ignoring the ps res "whine". engage the clutch as others have noted, it goes away. its highly "intermittent" and much less an annoyance than say, 2nd gear popout which can be endured for years, i suppose.
Old Oct 17, 2015 | 01:18 PM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
if your doing a GT2 clutch cyl conversion surely this will get rid of it as disconnect part of the pump for the clutch !!!!
Old Oct 19, 2015 | 12:47 PM
jimmy k's Avatar
jimmy k is a jewel in the roughjimmy k is a jewel in the roughjimmy k is a jewel in the roughjimmy k is a jewel in the rough
Hi Rick, yeah mine did not sound like that video. I thought it was the power steering reservoir and had it changed, but my whining sound did not go away. My whine was definitely lower in pitch (kinda like a horny cat-haha) and happened at lower rpms. Turned out to be one of the pulleys.
Good luck.
Old Oct 19, 2015 | 01:11 PM
MadWhip's Avatar
woahh. ^^ kinda like a horny cat-haha - lol
agentsmurf
Cayenne 955/957
Oct 17, 2015 02:10 AM
Stormdog
Sep 26, 2015 03:18 PM
carlosC4S
Cayenne 958
Sep 26, 2015 08:58 AM
JB GT3
Sep 24, 2015 10:01 PM
