BOSE (pre MOST) Amp Wiring - Help needed
Hi guys
At the moment I'm replacing the factory BOSE amp (in a 996TT) with an aftermarket one. But I really have trouble to identify which cable (connected to the amp) is for what…
I've already found Slider's wiring diagram https://www.6speedonline.com/forums/...eo-wiring.html, but I still miss the following information:
Greets
- which color have the cables from the amp to the subwoofer
- which color have the cables bringing the headunit audio signals to the amp
- which cable is the remote-on cable?
Greets
If you have the same amp as I do...Amp to factory subs is brown/white and white (they are slightly larger gauge than the other speaker wires coming from amp).
here is the wiring chart---->
Thanks gophaster, that helps…I'll take a look on it…
Thank yo ufor the offer, but I'd like to get rid of the BOSE system…
all the speakers are 2 ohm and aftermarket amps are mostly 4 ohm so speakers will need to be replaced. head unit as well.
But thanks anyway for your help. :-)
The wiring issue is speaker wires for the doors merge in the harness somewhere and a single lead enters the amp. No way to separate the left and right channels since I was running crossovers. It's not that hard to run all new better wiring just time consuming
cab83_750
10-23-2015 09:08 PM
jorligan
10-18-2015 01:57 PM
