fuel pump after 80000km
Old Nov 2, 2015 | 09:18 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
inspect fuel pump after 20000km with 5bar and 80000km over all
pump was only able to made 98psi
first picture shows the pump inside the collector was worn out / magnetic stator was lose and made some noises
so time to do a testversion
i use tim´s version and install a walbro 450 intank (excuse my dirt finger`s)
after install i do a log...afrs very good up to 1,5bar boost..pump is able to do more than 120psi ( engine is more powerfull and save)
a very good advice from tim ...thanks
ID:	431715   Click image for larger version
ID:	431716   Click image for larger version
ID:	431717   Click image for larger version
Old Nov 2, 2015 | 01:59 PM
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
Great data.
How long have you had the 5 bar fpr?
Old Nov 3, 2015 | 01:26 AM
winnigt2's Avatar
Originally Posted by pteck
Great data.
not to long only 20000km (pump all over had 80000km)
Old Nov 3, 2015 | 04:38 AM
itguy's Avatar
itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !itguy Is a GOD !
Take a close look at the wiring with the 450 (25amp+) the stock wiring is not rated to carry that much power, just something to keep an eye on.
Old Nov 5, 2015 | 07:26 AM
winnigt2's Avatar
Originally Posted by itguy
take a close look at the wiring with the 450 (25amp+) the stock wiring is not rated to carry that much power, just something to keep an eye on.
correct, thats a easy fix with a relay near the battterie and a mod at the connection
Old Nov 5, 2015 | 12:49 PM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
Also the pump flow falls off heavily up top because of an internal pressure valve. With the 5bar reg this will happen at 1.2bar off boost.
You can mod the top of the pump to increase the pressure of the internal valve and stop the drop off. I would recommend this for anyone with a 5bar.
Itguy can provide instructions
Old Nov 5, 2015 | 07:40 PM
rangerdick's Avatar
rangerdick has a spectacular aura aboutrangerdick has a spectacular aura aboutrangerdick has a spectacular aura about
Thanks for posting. Good information here.
Old Nov 7, 2015 | 01:22 PM
winnigt2's Avatar
Wink
flow range
Old Nov 7, 2015 | 01:23 PM
winnigt2's Avatar
current draw
Old Nov 15, 2015 | 02:31 AM
winnigt2's Avatar
i did the relay job at the fuel pump and had a gain of 0,8 volt
Old Nov 15, 2015 | 01:59 PM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
Can you explain exactly what is involved in the "relay job?" Parts needed, wiring diagram, etc. Sorry if I sound like an idiot, but electrical is not my forte. I am getting ready to swap out my whining pump with the Walbro as well.
Old Nov 15, 2015 | 02:40 PM
winnigt2's Avatar
cut the 2 cables at the connector at the fuel pump / let short cables stay at the connector / this 2 cables plus is green white and minus is brown connect with the relais/ green white to 85 and brown to 86 this will switch the relais on and off
(you can use this cables after cutting...long enough....
take a 4,0mm2 cable plus from batterie to the relais (30) and the output of the relais (87) to the plus connector of the fuelpump (you can soldering the ends together)
the minus cable from chassis (4,0mm2) to the minus connector direct to the fuelpump
ID:	432759   Click image for larger version
Old Nov 15, 2015 | 04:53 PM
ASLAN's Avatar
Thanks. That makes it a little clearer. I need to pull my pump cover to get a better visual.
The_Orange
Sep 28, 2017 09:08 AM
jastx
Dec 6, 2015 04:49 PM
JimTT
Nov 1, 2015 12:24 PM
VF Engineering
Lamborghini
Oct 31, 2015 03:13 AM
