So this happened.. (cracked intake distributor)
Old Jan 17, 2016 | 10:23 AM
Ronny-'s Avatar
Ronny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud of
I've been working on removing my engine today, and on the final stages where the intake manifold is detached from the intake distributor i somehow managed to crach the pillar where the bolt sits.
So do i have to replace the part or will it work to sand and glue?
Does anyone have this piece for sale? (not new)
Old Jan 17, 2016 | 10:48 AM
pwdrhound's Avatar
I would replace it instead of some jerry rig repair that will stare you in the face every time you open the lid. I would also recommend not to bolt the intake manifold to it as it puts a bit of stress on the plastic manifold which will eventually cause it to fail. I just have it free floating there without the bolt. The manifold will not go anywhere as it is held in place by the air box.
Old Jan 17, 2016 | 11:20 AM
jpflip's Avatar
When I took my engine out I had a crack exactly at this bolt attachment. I did the repair with fibreglass and it is holding perfectly since over three years.
Old Jan 17, 2016 | 11:23 AM
32krazy!'s Avatar
i have a complete spare i can fix you up
Old Jan 17, 2016 | 04:36 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
ive got a spare also
Old Jan 18, 2016 | 10:39 AM
Biovox's Avatar
Biovox is just really niceBiovox is just really niceBiovox is just really niceBiovox is just really niceBiovox is just really nice
This looks like a common weakness. Just having mine replaced too whilst the engine is out. Looks like PO tried a repair with glue that obviously wasn't strong enough. Cost of the part is ~200GBP+VAT here (which is nothing compared to the labour )
Old Jan 18, 2016 | 11:03 AM
SamboTT@ByDesign's Avatar
Happens a lot when the motor is raised or lowered too far. Repairs can be done decently if you had to. But with the motor out and awesome support here with a replacement it's a no-brainer! Don't feel bad its common.
+rep guys!
Old Jan 19, 2016 | 11:55 AM
Ronny-'s Avatar
Thanks for the feedback guys, im going to replace it.
At the same time im considering to strenghten it with some high temp carbon.
So this doesnt happen the next time i lower the engine.
Knowing my luck i will crack the new one when raising the engine back in
Old Jan 19, 2016 | 09:42 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Decently common problem. My hole was about 1x2 inches. I ended up making a .25 inch steel sandwich with silicone gasket material to fix it.
Old Jan 20, 2016 | 12:25 PM
replace it with a 997TT intake
#TeamAIM
Old Feb 3, 2016 | 08:06 AM
Ronny-'s Avatar
So this is how im trying to fix it.
I should probably leak test it afterwards.
Any ideas on how many bar/psi it should hold?
Old Feb 3, 2016 | 09:07 AM
i would test to 1.5-2 bar
#TeamAIM
Old Feb 3, 2016 | 10:12 AM
jpflip's Avatar
Very good repair.
Old Feb 3, 2016 | 10:51 AM
rmc1148's Avatar
Aren't these available relatively cheap used?
Old Feb 3, 2016 | 11:19 AM
Ronny-'s Avatar
I have an offer for 100dollars, but i figured since they are so easy to crack i would probably crack open the new one when fitting the engine again.. hehe
