abs module
Old Mar 15, 2016 | 02:25 PM
#9shooter's Avatar
#9shooter has a spectacular aura about#9shooter has a spectacular aura about#9shooter has a spectacular aura about
abs module
hey guys need some help. my abs module is messed up and im either trying to send it out to get it repaired or find one at a reasonable cost. i think Porsche sells it with the pump for over 3k trying to save a few bucks here anyone have any info that can help. thanks in advance everyone.
Old Mar 15, 2016 | 02:42 PM
pwdrhound's Avatar
I have a perfect condition ABS module that I removed from my 2002 996TT. PM me if interested.
John...
Old Mar 15, 2016 | 02:49 PM
pwdrhound's Avatar
Disregard post above. I just realized I sold the ABS pump a few months ago but still have the PSM pump and the YAW sensor. Sorry. Good luck with your search.
Old Mar 16, 2016 | 04:02 PM
Kaizu's Avatar
Kaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud ofKaizu has much to be proud of
How did you find out it's indeed the ABS module that's messed up?
I'm sure you know these cars inside out but just disclosing to other users that ABS failure is the most shown error in these cars and it has nothing to do with the ABS module.
Old Mar 17, 2016 | 11:11 PM
#9shooter's Avatar
my mechanic chased it down. i have been chasing this issue down for a while and changed sensors to correct the issue but never worked. one of my buddies told me about a guy that knew alot about 911's so he went threw the car and traced it back to the module..
Old Mar 18, 2016 | 06:54 AM
heavychevy's Avatar
ABS is a veryuncommon failure. What are symptoms? I have been told ABD pump before by very highly regarded mechanics and it was a boost leak. I have also broken the booster pump that gets vaccum from the engine.
If it truly is the module. May need to call LA dismantler.
Old Mar 18, 2016 | 04:25 PM
#9shooter's Avatar
so i went to my mechanic and was talking about how he figured it out. what kept popping up was a wheel sensor issue. all sensors have been replaced so he went threw every harness all the way back to the abs module and the wires are all good he hooked up a reader to the car took it for a ride and all the wheel sensors were reporting perfect so with the sensors all working and the wiring going back to the abs module sending signals 100 percent its pointing to the abs module . thanks heavy chevy i already spoke to them and they have what i need i was just reaching out on here to see if anyone had anymore leads to save a few. keep everyone posted on what happens
Old Aug 23, 2018 | 12:27 AM
bkj's Avatar
bkj
bkj is infamous around these parts
Having the same issue!
Having the same issue with my 996TT ABS module. Please help! How did you resolve this issue?
phiberglass
Merchandise For Sale / Wanted
Mar 17, 2016 11:42 AM
PelicanParts.com
930 Turbo Vendor Classifieds
Mar 1, 2016 12:22 PM
PelicanParts.com
993 Vendor Classifieds
Mar 1, 2016 12:21 PM
Britus05
Feb 28, 2016 08:24 AM
albert@velosdesignwerks
Feb 22, 2016 03:23 PM
