Converted over to Cobb Tune
Old May 20, 2016 | 07:51 PM
viprklr's Avatar
viprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond repute
So I converted over to Cobb tuning in order to bring my custom tuning closer to home. My shop got the tune installed & did a couple of pulls on the Dyno.
460hp/500lbs torque to the wheels. Good start.
Old May 20, 2016 | 08:14 PM
32krazy!'s Avatar
what was the prior tune? any chance you can make timmayfest in columbus oh june10-13? theres a bunch of turbos witihin a coupler hundred miles of the event and im trying to get as many as possible to go! its a blast!
timmayfest.com
Old May 20, 2016 | 08:53 PM
viprklr's Avatar
Prior tune was UMW. I would love to get to Columbus but I will at Mid Ohio instructing for OVR-PCA region that weekend.
Old May 20, 2016 | 09:27 PM
rockstardoc's Avatar
rockstardoc is a splendid one to beholdrockstardoc is a splendid one to beholdrockstardoc is a splendid one to beholdrockstardoc is a splendid one to beholdrockstardoc is a splendid one to beholdrockstardoc is a splendid one to beholdrockstardoc is a splendid one to beholdrockstardoc is a splendid one to behold
That's great. I was thinking of going with a Cobb Accessport. Are you able to save your old tune to the Accessport?
Old May 20, 2016 | 10:13 PM
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
The accessport is a great tool and really makes the porsche platform more viable for tuners and performance needs. No need anymore to jump through hoops. Any knowledge local tuner can work with you to keep the car at max performance and increase the power as you add mods.
Also the guages and the ease to log makes it probabaly the best all around thing to happen to the porsche performance community in a long time.
Old May 21, 2016 | 09:06 AM
SamboTT@ByDesign's Avatar
Very cool man those are some hefty gains that will translate into some serious speed banging through the gears! Mod list?
Old May 21, 2016 | 09:38 AM
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
What are your mods?
Old May 21, 2016 | 09:41 AM
devLost's Avatar
devLost is infamous around these parts
I have a stock turbo with a UMV tune. My intent is to go mild with a plenum and exhaust eventually. I have always liked Cobb Tuning, would I see any benefit from going with the accessport now? Or do you see the benefits really when going with a custom tune?
Old May 21, 2016 | 11:54 AM
viprklr's Avatar
I have UMW Z/C turbos, GT2 I/C's, LWFW, upgraded injectors/fuel rail, secondary fuel pump, upgraded Sachs clutch, KW3 Variant coil overs, Girodisc 2 piece rotors/padgid yellow pads, IPD plenum.
Old May 21, 2016 | 12:24 PM
pwdrhound's Avatar
Something wasn't right if you only dynoed 460hp/500lbs with UMW ZC turbos. Do you have the UMW K16/997GT2RS ZC turbos?
I have these and when I ran them on a stock engine I dynoed 590hp/630lbs on a dynojet. A stock 2015 ZO6 dynoed 589/613 on the same dyno right after we dynoed my car (ZO6 is listed as 650 crank front the factory). This provides a good data point for the dyno.
I had the following mods:
UMW 91 octane custom programming (1.25bar)
UMW injectors
RUF intake manifold / turbo intake hoses
RUF exhaust
Ported OEM exhaust manifolds
997GT2RS intercoolers
964RS LWFW
Here is the baseline dyno graph just prior to the engine rebuild.
[url=https://flic.kr/p/qtx6kF]
Old May 21, 2016 | 04:02 PM
Ursoboostd's Avatar
Ursoboostd is a name known to allUrsoboostd is a name known to allUrsoboostd is a name known to allUrsoboostd is a name known to allUrsoboostd is a name known to allUrsoboostd is a name known to all
timmayfest.com
I'm good friends with Tim. I was there last year. I'll be there this year as long as my employer doesn't send me out of town that weekend. -Wade
Old May 21, 2016 | 05:21 PM
32krazy!'s Avatar
awesome! make sure to say hello. first scotch is on me! my shop is working 7 days a week right now trying to get mine finished so i can attend
Old May 21, 2016 | 09:12 PM
viprklr's Avatar
The turbos are UMW K16/24.5 ZC. I was surprised it didn't dyno higher than it did. I was hoping to be in the 500hp range based on the parts.
Old May 21, 2016 | 09:42 PM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
I am going to be protuned with Cobb, I had EPL tuning before.
Old May 22, 2016 | 04:55 AM
32krazy!'s Avatar
1 thing i see in the pic and from your list is you have really small i/c and the fans are a good distance away. when on the dyno you need the fans to be as close to the bottom of the i/c as possible and turbned up as fast as they will go blowing fresh air backwards thru the i/c you may be heat soaking the i/c quickly in the shop. also what inj are you running? its certainly possible you may have some fuel issues.
