Methods to lower IATs
Old Aug 24, 2016 | 05:32 PM
OK51MON's Avatar
OK51MON is infamous around these parts
Lightbulb Methods to lower IATs
Im running 997 gt2 rs intercoolers but I'm still have trouble with heat soak.
How can I stop this?
Wrap my headers?
Si
Old Aug 24, 2016 | 05:43 PM
infinkc's Avatar
infinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to beholdinfinkc is a splendid one to behold
If it's that bad still I would look at adding water/meth injection.
Old Aug 24, 2016 | 07:24 PM
BLKMGK's Avatar
Larger intercoolers? Under what conditions are you seeing heat soak that badly?
Old Aug 25, 2016 | 03:58 AM
OK51MON's Avatar
I would drive 15 minutes to the gym on a cold start. Then when I drive home again Id lose like 30 bhp
Im based in the UK
Old Aug 25, 2016 | 08:22 AM
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
Why are you assuming it's heat soak? And how long do you work out? 2m30s?
Old Aug 25, 2016 | 09:07 AM
pwdrhound's Avatar
Im based in the UK
Something else is not right. It's not your 997.2s. On a warm day it takes me about 4 hard laps of continuous full throttle upshifts (8+ mins) to notice a drop off in performance due to heat soak and even then it's only about 1 second per lap. No way will you saturate them on the street driving to the gym.
Old Aug 25, 2016 | 07:20 PM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Make sure the air box and scoop on the deck lid are sealing correctly by adding some D Shape stick on rubber weather strip
Old Aug 26, 2016 | 02:55 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
the only power loss you can feel at city driving is a def engine compartment fan......
check if this fan is running / and the level 2 is working with durametric
Modern Walker
Apr 10, 2016 03:57 PM
sharkster
Aug 27, 2003 05:16 PM
watt
Jul 30, 2003 07:23 PM
