996TT Budget Full Bolt-On Street Build
Old Sep 30, 2016 | 09:41 AM
  #46
dubulup's Avatar
dubulup is infamous around these parts
Fawker.
I'll be in town late October
Old Sep 30, 2016 | 09:57 AM
  #47
SpeedAddict's Avatar
SpeedAddict is a name known to allSpeedAddict is a name known to allSpeedAddict is a name known to allSpeedAddict is a name known to allSpeedAddict is a name known to allSpeedAddict is a name known to all
Originally Posted by dubulup
Fawker.
Good, its making so much power the clutch is slipping.... You can come hand me wrenches while I change it.
Old Oct 1, 2016 | 11:47 AM
  #48
32krazy!'s Avatar
what are you looking t0 replace the clutch with? call me before buying anything!
Old Oct 5, 2016 | 10:37 PM
  #49
32krazy!'s Avatar
Old Oct 5, 2016 | 11:03 PM
  #50
pwdrhound's Avatar
Originally Posted by 32krazy!
Best clutch out there for moderate power applications...
Old Oct 6, 2016 | 07:01 AM
  #51
Thanks Guy's, that would have been perfect... Unfortunately, he already sold it.
Old Oct 6, 2016 | 07:50 AM
  #52
Forgeline
Forgeline GA1R Wheels and BFG Rival tires arrived! Thanks a bunch to Steve at Forgeline, he was great to deal with and the wheels are a work of art. Thanks to powderhound for the offset & tire sized recommendations. Wheels are 18x12 & 18 X 9 and tires are 315/30/18 & 245/40/18. These really fill out the fender wells and have a pretty aggressive look. Here's a teaser pic until I can get some good ones in the daylight.
Old Oct 6, 2016 | 01:20 PM
  #53
32krazy!'s Avatar
Old Oct 7, 2016 | 09:44 AM
  #54
s65e90's Avatar
s65e90 is infamous around these parts
looks good, but the front tire is tall. Why not run the 235/40 which is the match to the 315/30?
Old Oct 7, 2016 | 09:52 AM
  #55
Thanks, Rear are 25.5 and front 25.7 The height difference is so minimal that it's not noticeable with them side by side. I chose the 245 for A couple of reasons. 1-BFG does not make a 235, 2-I wanted the extra width(grip) up front.
Old Oct 7, 2016 | 04:44 PM
  #56
BLKMGK's Avatar
If still AWD you want taller up front. Not seeing an LSD listed so assuming it's AWD still.
Old Oct 7, 2016 | 05:00 PM
  #57
Yes, still AWD. Looks like I'm good to go then!
Old Oct 7, 2016 | 05:10 PM
  #58
BLKMGK's Avatar
I'm not 100% on the proper ratios front to rear so double check before spending cash. I'm sure that if the rear were taller it would be bad for the diff up front and having the wrong ratio too far out will trigger PSM errors and traction control.
Old Oct 7, 2016 | 07:02 PM
  #59
No worries, I did check before I bought them. They work well with no Psm problems. The poster S65E90 was asking why I went with this setup.
Old Oct 10, 2016 | 05:24 AM
  #60
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Question
Did a boost leak test with Marksi's setup and found the throttle body o-ring was leaking and one of the vaccum lines. Installed new throttle body gasket and zip tie'd every vaccum line I could find. Put her all back together and she is air tight now. Installed the APE airbox that I scored from the classified section and spent a lot of time fitting and had to slot the mounting bracket but in the end it came out nice.
Mike, if you havent done so if I were you mate id be looking at adding stick on rubber 'D' seal around where your intake scoops meet your airbox. There is more to be made if you can get that area really sealed up well.
