Help ID Codes - Please
Old Jan 17, 2006 | 11:35 AM
Turbochris's Avatar
Turbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond repute
Had a code, o2 sensor..........replaced the sensor and cleared the code....fine for 24 hours and then I get another CEL. This time I get these...
PO410 - Secondary air system - cyl 1-3
P1411 Secondary air system - 4-6 - signal
Anyone know off hand what these are???
Chris Barton
Old Jan 17, 2006 | 12:10 PM
Ruiner's Avatar
Well, if www.renntech.org wasn't timing out, I would research it for you some more...
I wonder if you have a vacuum leak...
Old Jan 17, 2006 | 05:58 PM
Turbochris's Avatar
When I start it up first thing in the morning,,,,,I do sometimes hear every so slight of groaning....might be the DV's??
Chris
Old Jan 17, 2006 | 05:59 PM
Ruiner's Avatar
Chris
Groaning?
Old Jan 17, 2006 | 06:37 PM
Turbochris's Avatar
Yeah, wierd, but when I blip the throttle slightly and put it in gear (first couple of times after a cold start) it kinda goes HMMmmmmm....kinda like a groan.,.....I wondered if that might be my cars version of the "Honking" that people say signifies the end of DV's....
Chris
Old Jan 17, 2006 | 06:39 PM
Ruiner's Avatar
Chris
My advice would be to look at the diverter valves (and the hoses that connect to them) to see if any are loose.
Old Jan 17, 2006 | 06:43 PM
Turbochris's Avatar
My thoughts too, just thought maybe someone here could identify the codes I am generating........that would be a big help too....
Chris
Old Jan 17, 2006 | 07:23 PM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
p0410
DME 7.8 DME 7.8
P0410
80 Secondary Air Injection System, Bank 1 – Below
Limit
Diagnosis conditions
• Intake air temperature 4.5 - 60 °C
• Engine temperature 4.5 - 102 °C
• Mass air flow 36 - 150 kg/h
• Engine starting temperature less than 42 °C
• Altitude correction factor greater than 0.75
• Oxygen sensors 1 and 2 ahead of TWC are ready for operation
• The secondary air injection pump is switched on
• Diagnosis has not yet taken place during this cycle
Possible fault cause
. Secondary air injection pump is not triggered
. Secondary air injection pump does not work
. Air supply lines restricted
. Electric change-over valve does not function
. Air change-over valve does not function
. Vacuum system leaking
Affected terminals
III/11 and III/14
Diagnosis/troubleshooting
2665 P0410 0-58 page 1Printed in Germany – 1, 2000 p0410
DME 7.8 DME 7.8
Note!
Secondary air diagnosis can be activated with the Porsche System Tester 2 in the "Short test" menu.
Work instruction Display OK If not OK
1 Activate secondary air
pump.
. Remove relay of secondary air
injection pump.
. Jumper terminals 30 and 87.
. The secondary air pump must
be running (audible function).
– or
. Connect and switch on Porsche
System Tester 2.
. Select DME.
. Call up "Drive links" menu.
. Select "Secondary air pump".
. Activate secondary air pump
(audible function).
. Step 3 . Step 2
2 Check triggering of secondary
air pump
. Check fuse (Maxi Fuse) of AIR
pump (on relay carrier 2).
. Remove relay of AIR pump (on
relay carrier 2).
. Measure voltage between pin 3
and ground
. Push relay back on.
Battery positive voltage
Check wire from pin
2 to DME control
module pin III/11 for
continuity.
. Remove connector of AIR pump.
. Measure voltage at pin 1 and pin
3 Check vacuum system for
leaks
Seal vacuum system
4 Check electric changeover
valve
. Remove two-pole connector of
electric change-over valve.
. Trigger AIR pump with Porsche
System Tester 2.
. Remove vacuum hose of electric
change-over valve with the
engine running.
Vacuum must be
present
0-58 page 2 2665 P0410
p0410 Printed in Germany – 1, 2000
DME 7.8 DME 7.8
5 Check air change-over
valve
. Run engine briefly to produce
vacuum.
. Activate secondary air pump.
. Remove vacuum hose of air
change-over valve.
Vacuum must be
present
. After activation, check air
change-over valve for continuity
6 Check air supply lines for
blockage
2665 P0410 0-58 page 3Printed in Germany – 1, 2000 p0410
DME 7.8 DME 7.8
0-58 page 4 2665 P0410
Old Jan 17, 2006 | 07:24 PM
rmrmd1956's Avatar
p1411
DME 7.8 DME 7.8
P1411
208 Secondary Air Injection System, Bank 2 – Below
Limit
. Vacuum system leaks
Affected terminals
III/11 and III/14
2665 P1411 0-167 page 1Printed in Germany – 1, 2000 p1411
DME 7.8 DME 7.8
Note!
pump
injection pump.
– or
System Tester 2.
. Select DME.
(audible function).
. Step 3 . Step 2
air pump
relay carrier 2).
and ground
Check wire from pin
2 to DME control
continuity.
leaks
Seal vacuum system
valve
System Tester 2.
engine running.
Vacuum must be
present
0-167 page 2 2665 P1411
p1411 Printed in Germany – 1, 2000
DME 7.8 DME 7.8
valve
vacuum.
change-over valve.
Vacuum must be
present
. After activation, check pneumatic
blockage
2665 P1411 0-167 page 3Printed in Germany – 1, 2000 p1411
DME 7.8 DME 7.8
0-167 page 4 2665 P1411
Old Jan 17, 2006 | 07:54 PM
PorschePhd's Avatar
This is a code almost always associated with the vacuum line to the DVs. It will self check within the first 5 minutes of "cold" start up and not again until it cycles to complete cold again..
Old Jan 20, 2006 | 05:48 PM
Turbochris's Avatar
So, in your opinion....probably a leaky line or leaky DV's? Boy, wouldn't it be nice to be a part that I wouldn't mind upgrading anyways......well, it's going over to GMG monday so we can fix. Hope that's what it is....
Chris
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
PelicanParts.com
997 Vendor Classifieds
Oct 5, 2015 01:07 PM
Oct 2, 2015 02:23 PM
nagual911
Oct 1, 2015 01:52 AM
