996t clutch problem
Old Jul 18, 2019 | 11:41 AM
2ltrrabbit's Avatar
2ltrrabbit is infamous around these parts
996t clutch problem
Hi
I’m new to site so may need to be guided around.
Ive recently purchased my 1st Porsche and
I have a slight problem with the clutch already.
when I give her a full throttle run I get the clutch pedal drop or lose pressure between gear changes. Pump the peddle a few times and it comes back.
theres no leak what so ever.
car is heavily modded and has a gt2 type clutch set up
any help or guidance very great-full.
thanks in advance
steve
Old Jul 18, 2019 | 09:52 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
not totally sure I understand the situation it's happening under, but sounds like a bad master cylinder
Old Jul 19, 2019 | 03:50 AM
2ltrrabbit's Avatar
Basically it’s when I do a full power and full revs run up through the box.
When I need the next gear my clutch pedal will travel half way down befor I get any resistance.
Normal driving no problem at all.
It seems to be high rpm related.
It won’t be the master cylinder as this has done its job by the time the fault occurs.
for example if I short shift at 5k rpm no problem
but if I shift at 6.7k problem occurs.
I will change fluid as routine to see if it helps.
The clutch has a solid lightweight flywheel, which is very noisy under low rpm and slight load. I’ve heard this is common. But I wonder if it’s resonating so much it’s affecting the slave?
Regards
steve
Old Jul 19, 2019 | 10:59 AM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
Sounds like your slave cylinder could have some issues with the hydraulic assist when at higher rpm. It has a valve in it that applies pressure to help actuate the clutch based on pedal pressure. if that was leaking internally it could partially actuate?
Old Jul 19, 2019 | 11:11 AM
2ltrrabbit's Avatar
I don’t have the assisted clutch set up. It’s the gt2 setup.
Thanks tho
Old Jul 19, 2019 | 05:17 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
You might have a leak that is letting air in
Old Jul 20, 2019 | 12:23 AM
2ltrrabbit's Avatar
She’s dry. No leak or signs of old leaks.
Will try to bleed the old fluid out today and see what happens
thanks for ideas
Old Jul 20, 2019 | 08:00 AM
bushrat's Avatar
bushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond repute
thanks for ideas
Went to a BBI setup, bled for over an hour with the pedal with no luck. Bought a $20 vacuum bleeder off the Wish site
, hooked it up to the slave bleeder and had it bled within a few minutes.
2000gt
Mar 9, 2018 09:57 AM
Yazz911TT
Dec 1, 2013 03:10 PM
NBTBRV8
Nov 21, 2011 11:54 PM
porsche4391
Apr 28, 2008 08:09 PM
