Oem caliper upgrade option for 380mm front rotors?
Subscribe
Jul 21, 2021 | 04:05 PM
Has anybody swapped to larger six piston OEM calipers with the Brembo 380mm front rotors?
I was thinking about upgrading to a stronger caliper on the front, o have the 4 piston brembo s with the brembo 380mm rotors now.
I heard the 997 gt3 calipers may fit? Are those the same as the 991 calipers?
Any info is appreciated.
Reply
Jul 21, 2021 | 07:08 PM
Should be some good threads on this, did you see this one, search is your friend? I'm sure there are others, Pwdrhound has been tracking his car for years, and probably one of the better resources period for these cars, as I believe he still posts on occasion. I stopped at 350mm, as I have no plans to track the car.
https://www.6speedonline.com/forums/...our-996-a.html
Reply
Jul 21, 2021 | 07:13 PM
https://www.6speedonline.com/forums/...80mm-disc.html
Reply
Jul 22, 2021 | 07:13 AM
Thanks guys, I found a lot of good threads. Thank you.
my big concern was the right offset of these 380 mm brembo rotors I have.
Assuming they are standard offset looks like I need front calipers of a 997.2 GT3 or a 991 GT3.
Reply
Jul 22, 2021 | 09:55 PM
Are there adaptors for 130mm to 225mm calipers?
I measured my caliper bolt spacing at 130mm, I thought they would be 146mm. Wierd
Reply
Jul 23, 2021 | 08:33 AM
If go up to the 380MM you are pretty much locked into 19 inch rims. I went with the 350MM upgrade and really like them. All Porsche parts.
Reply
Jul 30, 2021 | 05:56 PM
I run 7.2GT3 380mm brakes with 18" wheels... Only a handful of 18 will fit 380 brakes... I see no point of doing 380s on a street car..
Reply
Aug 31, 2021 | 05:47 AM
350mm upgrade
I wanted to upgrade to slotted 350mm rotors. My stock drilled rotors got pretty ugly after the last track outing at watkins glen. I ordered the bushings and bolts from the guy on ebay a couple weeks ago. I sent a few messages and have not heard back. I more track days the following weekend so I only have a week and a half to sort it out. Does anyone have info on making your own spacers and what bolts to source. I have a CNC router that I can cut aluminum on. I would like a back up plan in the event I do not get the parts I ordered.
thanks
Todd
Reply
Subscribe
