The 996TT is a HORRIBLE drag racing car!!
With that being said, I think that it's incredible that guys are throwing up the kind of times that they are in these cars.
It seems that our friends in Stuttgart have done everything possible to keep us from ripping low ETs in these cars:super short 1st gear, AWD that's next to impossible to launch, six speed transmission that requires you to fully disengage the throttle at least 3 times on your way to the finish line, turbos that can't be spooled on the pre-launch, super tight suspension that gives almost no weight transfer for launches, big brakes that require big wheels and tires, I could go on...feel free to add to the list.
With that being said, how cool is it to have a car that runs like a bat out of hell in the 1/4, eats everything up on a roadcourse and then drives like a mild mannered every day car around town.
With some of the trap speeds I've seen on these cars, if you fitted a modded 996TT with a Detroit locker rear end and torque converter, a 3-speed power-glide transmission, 16" wheels with ET Drag tires, a 2-step turbo system to deliver max boost on take off, line-lock, a trans-brake and a super soft suspension for max weight transfer I think we would see 8 second passes on a routine basis. But then again, It wouldn't be a Porsche that has all of the traits that we have come to know and love
This has always been my point of these super modded super high HP TT's whats the point if you want to drag race get a viper or a Z06 and save your $$$. The 996 finest point is when it is rolling already like any other TC car.!
Originally Posted by 01TT
Just curious, why is the AWD "next to impossible to launch" in the 996TT? Is the AWD system in the Porsche worse for drag racing than it is in say an Evo, S4, etc?
Why do you need weight transfer when launching an AWD car?
AWD is not good for drag racing in any car. That's why all the really fast cars are RWD. You want weight transfer in a RWD car so all the weight can squat down over the rear wheels and launch you like you were shot out of a gun, here's an example:
http://www.scottsdaleexoticcarclub.c...vythunder.html
You're not going to make an AWD 996 lift the front wheels off of the ground like that.
Guest
Posts: n/a
and here is what in in-car 7second ride looks like from inside.....my poor camera...
http://media.putfile.com/ChowDog-Record
Hey Joe,
Would'nt it be nice to launch our turbos with 32psi on the transbrake?
BTW...You did mean to write '2-speed power glide' and not '3speed power glide' ??
Hey Joe,
I understand why the weight transfer is necessary in a RWD car, but why is it needed for an AWD 996TT?
I agree that RWD is far superior to AWD for drag racing but I was just wondering if the Porsche's AWD system was any worse than the system used in Evos, S4s, etc. My S4 has pulled high 1.5 60fts at the dragstrip... definitely not as good as most RWD cars set up for drag racing, but still, I wouldn't call that next to impossible to launch either.
My S4 has done mid to high 1.5's at the strip. My buddy's Evo has done 1.5's as well and he's only putting down 300-325 to the wheels! I also know other guys with Evos, DSMs, etc. that are pulling better than 1.5 60fts. Does the 996TT's rear engine setup make it more difficult to launch with the AWD intact?
Interesting... I wonder how the 996TT would do with stock tires on the front and drag radials or slicks in the back while retaining the AWD...
Yeah, the S4 has something similar to that called EDL. My car has a kill switch which disables it while retaining the ABS. Has anyone figured out a way to completely disable the PSM in your cars?
That's odd... Why do you think it wheel hops like that? Does it have something to do with all the weight being over the rear wheels combined with the AWD?
I believe your information is not correct.
