EVO waste gate springs
Old May 31, 2006 | 04:07 PM
tom kerr's Avatar
Just go em anyone with any experience with these, got them mostly in preparation for the ECU flash wasnt sure if would notice any difference or was it a waste of $ (they didnt cost much)
TIA
Old May 31, 2006 | 06:34 PM
WOODTSTER's Avatar
HUH?
Marty
Old May 31, 2006 | 06:51 PM
Usuallly stiffer springers do help spool up and sustain boost... the flap doesnt flutter as in the stock springs under higher boost levels...
different tuners use different springs... some use 12 bar some use 1.2 bars....
just make sure they will be set just below the thresh hold b4 u hit 1.3 bars.. so u dont close the TB.
I had that problem but used a boost controller to get around this issue and I also had the diode installed to avoid the TB shut down.
mark
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 31, 2006 | 08:41 PM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
are new wastegate springs better than having the stock ones "calibrated"? I'm not sure exactly what that means, but my stage 4 upgrade included "wastegate calibration"
thx
Old May 31, 2006 | 09:13 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
mark
So Mark...what would be a better choice....the EVO wastegate spring upgrade or a Greddy boost controller for someone running Stage 2?
Old May 31, 2006 | 09:23 PM
well, u have only stage 2 running on stock k16s... tahst ur limiting factor...
so anything u do will not produce real power unless u have k24 hybrids...
u can do the greddy and play a little... maybe sustain a nice 1.1 bars max.
u can also just turn up ur springs a turn or two and mabe ull get some more juice out of her... again not much(k16s). u can also go with stiffer springs but again.. k16s
mark
9.66
click to view
Old Jun 1, 2006 | 01:15 AM
iLLM3's Avatar
mark
Yea i gathered same thing after lots of talking with mark lol, im going to give it a try with my v flow i will be putting with the evo wastegates! Probably a waste considering im def. going to upgrade the turbo's and so on, but w/e, no harm in trying it out!
BTW Mark didnt know you cna use a boost controller to alter boost level with the 996tt's?!
Old Jun 1, 2006 | 01:35 AM
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
Hey Martin, keep me update with your wastegate spring upgrade. I want to have little more from my stage 2 before turbo upgrade.
Old Jun 1, 2006 | 01:37 AM
iLLM3's Avatar
I'll keep you updated Ray
Old Jun 2, 2006 | 11:50 AM
tom kerr's Avatar
Ok drove the car alot with the new wastegates. This is just what I observed. Car used to peak boost at 1.0 and go to 0.9 and then drop some more. Now I see 1.1 (never did before) and holds at 1.0 as long as the pedal is down. this is with a stock X-50 with race cats and straight pipes.
Seems like a good improvement?!
Old Jun 2, 2006 | 01:13 PM
iLLM3's Avatar
Well the only noticeable power increase/gain will be where you are sustaining, and for you that is the 1.0 bar instead of the .9 steady. .1 is definitely noticeable and can equate to what, like 20-30 hp if im not mistaken, i though i was told or read that somewhere, forgot though. Anyway i doubt it would be extremely noticeable but i do believe you got a pretty good gain, better throttle response and so on!
BTW you dont want it boosting any higher, your hoses will start flying off left and right
Old Jun 2, 2006 | 02:53 PM
u can push ur stock k24s to 1.2 bars... so if turn up ur WGs one full turn clockwise... u should be just fine
9.66
click to view
Old Jun 2, 2006 | 05:46 PM
jaykla's Avatar
jaykla is a jewel in the roughjaykla is a jewel in the roughjaykla is a jewel in the rough
Any better throttle response? More importantly, less lag?
Old Jun 2, 2006 | 05:53 PM
the boost comes on faster... and it holds boost better....
the trick is to have a program tuned for external WG control... just like in all other turbo cars.... via a boost controller.. thats just my opinion..
9.66
click to view
Old Jun 2, 2006 | 10:16 PM
tom kerr's Avatar
thanks Mark and you are right!!
