evo intercoolers
Old Aug 16, 2006 | 07:43 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
evo intercoolers
just switched my gt2 ics for the new ics from evo. (got mine from sharkwerks) Tod at evo was fast to the draw and got my hoses to me in two days. got the red ones to get a little color , they are lookin good, as far as performance, no acid test yet. but seems to come on faster and less loss between gears only got in it twice....so far i am impressed... have an extra set of gt2 ics
Old Aug 16, 2006 | 07:44 PM
sharkster's Avatar
Glad it worked out Steve... by the sound of it you were needing the hoses anyways Check the for sale section as someone was looking for GT2 ICs!
Old Aug 16, 2006 | 07:53 PM
ics
thax alex i do feel they will be an asset my tuner in rocklin is very impressed... as i a just no seat time yet.....they do feel way stronger just going thru the gears.
Old Aug 16, 2006 | 08:38 PM
vipertestarossa's Avatar
vipertestarossa is a jewel in the roughvipertestarossa is a jewel in the roughvipertestarossa is a jewel in the rough
I am in the final stages of the GT700 completion on my GT2 and I am now installing the EVO intercoolers...they are much larger than stock and beautifully built, the stock brackets had to be heavily modified and the body underneath the tail lights as well, cant wait to run the car with these!
Old Aug 16, 2006 | 08:40 PM
ics
you will like them!!!
Old Aug 17, 2006 | 12:45 AM
Zippy's Avatar
My cars going in Monday to get them installed.
Old Aug 17, 2006 | 02:28 AM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Why was there so much modification? Do teh gt2's require more work. When I did mine, all I had to modify was the oem ducts(some trimming), cut a small amount of metal off the body, and expand the size of the hole in the IC bracket.
Jag
Old Aug 17, 2006 | 11:12 AM
oak's Avatar
oak
I thought they were supposed to be a stock replacement with no modifications, what type of metal hacking involved?
Old Aug 17, 2006 | 11:34 AM
woolyg's Avatar
woolyg is infamous around these partswoolyg is infamous around these parts
They were ):
Old Aug 17, 2006 | 12:58 PM
jags911tt's Avatar
You must remove the plastic lip around the oem ducts. Then there is a hole on the bracket which must be drilled out to 3/4 inch, and finally a small amount of metal is removed from the body. Not too much hacking at all. Put it this way if you do this mod and want to go back to stock IC's then you will need new oem ducts.
Jag
Old Aug 17, 2006 | 01:00 PM
oak's Avatar
oak
jags, how much of the body and where? will there be and actual hole through the metal?
Old Aug 17, 2006 | 01:04 PM
jags911tt's Avatar
Yep and this should give you an idea
Old Aug 17, 2006 | 01:13 PM
oak's Avatar
oak
jags, thanks for the pics. I was hoping there would be no "grinding".
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
leevg
New Member Introductions
Sep 28, 2015 05:59 PM
