Resistor for Airbag DELETE
Old Feb 17, 2004 | 11:54 PM
Cary Eisenlohr's Avatar
Cary Eisenlohr is just really niceCary Eisenlohr is just really niceCary Eisenlohr is just really niceCary Eisenlohr is just really nice
Has anyone figured out the resistor needed to allow the removal of the Airbag without getting the light and error on the dash.
Old Feb 18, 2004 | 08:49 AM
viperbob's Avatar
viperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud ofviperbob has much to be proud of
Have not done it on a 996TT. For the 993tt it is a 2.8 ohm 1/4 watt..
Old Feb 18, 2004 | 02:14 PM
Very cool! That's what I was looking for. Would is make since that it would be the same on a 996? Is there a way I can check it?
Old Feb 18, 2004 | 04:18 PM
karlooz's Avatar
Senior Member
karlooz is infamous around these parts
how about removing the bulb behind the airbag error light?
Old Feb 19, 2004 | 03:23 AM
The problem is the readout in the dash still reads an error and you have to clear it everytime you start the car. It would be nice to just make it go away.
Old Nov 26, 2018 | 05:26 PM
01Turbo's Avatar
5 Year Member
01Turbo is a name known to all01Turbo is a name known to all01Turbo is a name known to all01Turbo is a name known to all01Turbo is a name known to all01Turbo is a name known to all
Bump this thread .....
hoping someone has done this as i bought a Renown steering wheel i want to put on a 996TT
Old Nov 27, 2018 | 03:56 AM
arjayr33's Avatar
arjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond repute
Waiting for a chime in on this one I just replaced my oem steering wheel to a flat bottomed quick release Momo and lovin it but the dash light is annoying!
Old Nov 27, 2018 | 08:07 AM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
Try posting in the 996 and Boxster rooms.
Old Nov 27, 2018 | 09:43 AM
s65e90's Avatar
s65e90 is infamous around these parts
A resistor from 2.8 to I believe a 3.2 ish will work fine. To make it all work, you need the following:
On a 996 the horn is also part of the clock spring. You can buy the 964 horn piece from Porsche and I also bought a used clockspring from another 996 911 so I didn't have to cut mine (996, boxster are all the same). You need to solder the resistor inline where the airbag once was. When you install the 964 horn bushing it has a contact so the horn can be pressed and sound off. You need to then add a wire to the back of the control stalk and it will allow the horn to work. Once put back together, everything should work as normal and you should not have an SRS light.
Follow this thread, it's very good.
https://rennlist.com/forums/993-foru...ng-photos.html
Old Nov 29, 2018 | 06:44 AM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
^ +1
can be a bit of a finicky job to do nicely.
Will lose sight of upper half of some gauges with standard height seats/ typical 350mm wheel
Old Nov 29, 2018 | 09:02 PM
01Turbo's Avatar
5 Year Member
I will be running a 330mm wheel and will eventually upgrade the seats so hopefully i wont have that problem @ 993GT
Old Nov 30, 2018 | 04:02 AM
arjayr33's Avatar
dash light
gracias!
Old Nov 30, 2018 | 05:00 PM
pwdrhound's Avatar
Here is a link to the non airbag steering wheel conversion. I know we used a resistor but can't remember what size.
https://www.6speedonline.com/forums/...l-install.html
Old Dec 1, 2018 | 12:37 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
works on all airbags...including passenger front and side/door
WheelsupZR1
Oct 20, 2015 08:36 PM
Oct 2, 2015 02:23 PM
hollynitro
Oct 1, 2015 02:40 PM
nagual911
Oct 1, 2015 01:52 AM
