Interpreting results from inspection...
Old Jan 26, 2007 | 05:36 PM
PsyFi's Avatar
PsyFi is infamous around these parts
Well I had a local Porsche dealership do an inspection.
Most everything on the list was checked "ok".
He noted the car has only 200 ignition cycles in Range 2
Trans solid in 2nd gear
for Suspension he put down " rear sway bar links"
Both bulbs in front out
brake fluid flush - dirty
Paint on hood is 7.5-8.0 MILS thick
Paint on all other metal parts 3.0-4.5
Clear coat peeling on left front brake caliper
Anyway I'm a noob at all this so any help would be greatly appreciated.
All other items were checked ok
Its an 02 TT with 45K miles
Thanks again
Old Jan 26, 2007 | 08:20 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
paint thickness tell you of repaint...
Old Jan 26, 2007 | 08:29 PM
PsyFi's Avatar
So maybe the hood was dented or scratched?
Old Jan 26, 2007 | 08:34 PM
rosesplus's Avatar
rosesplus is infamous around these parts
Who knows, could have been stone chips which as are pretty common up front. It is more likely to have been cosmetic. With 45K miles, I'd be pretty happy with the report, if that's all they came up with.
Old Jan 26, 2007 | 08:54 PM
tom kerr's Avatar
Thanks again
if that range 2 thing is type two over revs that could be a problem, ask them.
Old Jan 26, 2007 | 09:15 PM
PsyFi's Avatar
Yea I talked to guy at the Porsche dealership....Park Place in Texas. I was in a hurry and can remmber a few thing he said. he said something to the effect that maybe once for a fraction of a second there were 200 ignition cycles. But he gave the car an overall clean bill of health.
But I still want to make sure
Old Jan 26, 2007 | 10:31 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
On the rear sway bar links, it could be possible he was referring to the rear toe links, which can get bent easily, lots of tow drivers like to use them as tie down points, which they most certainly are not.
Old Jan 27, 2007 | 01:56 AM
notquitefob's Avatar
notquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud of
the range 2 over rev looks like he just bouce off the rev limiter maybe once or twice. the iginition cycle is how long the car spent in "range 2" which I believe is above the first redline. 200 iginition cycle is like a quick bounce off the line, no worries.
a mechanical over rev would have ignition cycles in thousands. the front "could" be a respray of chips, but a better way to check for collision is to check under the car in the front for weld or new bolts, or check in the front hood for repaint under the carpet lining. a collision would require more paint than just the hood. other than that, a dent or scratch on the hood is nothing to worry about.
good luck, hope that helps.
ModBargains
Lotus Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
bshah1976
Sep 12, 2015 07:37 AM
