Dension Gateway 500 iPod interface installed
Old Feb 16, 2007 | 08:35 PM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
Dension Gateway 500 iPod interface installed (pics)
After all the years of waiting, I finally have an iPod installed in my 911.
I have a 2003 which was the first year of the MOST fiber optic system.
So far the system works well. I have not really used the car much due to the winter weather.
I did a test hook up before making the effort to properly install the system to make sure everything was working. This install was surprisingly easy. I had a factory CD changer and just used the power from the CD line and of course the fiber optic line that went to the CD changer. I installed everything into the trunk as I do not need to access the iPod since the radio can control it. I rather have less inside the passenger compartment anyway.
Here is a link to my install picture. I do not have radio pictures yet but you can see all the songs on the Nav screen. Pretty slick.
http://web.mac.com/periokid/iWeb/Sit...way%20500.html
Thanks to Eric at bumperplugs who got us these systems as soon as it was possible.
Old Feb 16, 2007 | 09:01 PM
HdS's Avatar
HdS
HdS has much to be proud ofHdS has much to be proud ofHdS has much to be proud ofHdS has much to be proud ofHdS has much to be proud ofHdS has much to be proud ofHdS has much to be proud ofHdS has much to be proud ofHdS has much to be proud of
How does it work after? How do you control the music? Do you get the playlist on the nav. screen?
Old Feb 16, 2007 | 09:07 PM
Periokid's Avatar
You can control it from the headunit.
Old Feb 16, 2007 | 09:24 PM
acf's Avatar
acf
acf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to beholdacf is a splendid one to behold
Thanks for the install pictures!
Old Feb 16, 2007 | 11:59 PM
Periokid's Avatar
Sure thing. Just an idea for some on how to install it. I am sure others will do it differently.
Old Feb 17, 2007 | 12:23 AM
acf's Avatar
acf
I've never spliced wires before, everything else looks fairly straight foward. Could be fun?
Old Feb 17, 2007 | 09:49 AM
Periokid's Avatar
No real splicing required. With the crimp connectors (the blue ones in the photos) it is easy to get power without stripping any wires. The fiber optic connections are very easy, they just slide together and by pressing a tab, it locks together. Much easier then I anticipated!
Old Feb 17, 2007 | 01:35 PM
acf's Avatar
acf
Thanks PerioKid, Me and a buddy are going to give it a go this weekend probably. If all fails, off to GMG. Is there any particular reason why you just didnt devote the cd changer power to the denison unit? Seems like you'd never use the cd changer again, and it's cleaner that way. If you needed to return back to stock for resale you could always add the cd changer power connector back? Aside from removing the cd changer, what panels are required for removal?
Old Feb 17, 2007 | 03:47 PM
Valley996TT's Avatar
Valley996TT is just really niceValley996TT is just really niceValley996TT is just really niceValley996TT is just really nice
Can you hook up Sirius/XM radio to this and work it from the Nav head unit? If so, what Sirius/XM unit would work?
Old Feb 17, 2007 | 04:28 PM
Periokid's Avatar
I did use the CD power for the dension unit. I just did not cut off the connector to the CD. That way I could return it to stock easily. The blue connectors tap tight into the harness of the CD power line about 4 inches from the connector.
The only panel to remove is the passenger side rear panel in the trunk. It does not even need to be removed completely for good access.
Old Feb 17, 2007 | 04:29 PM
Periokid's Avatar
You could use the AUX inputs for something like that but you would not have control of the Sirius/XM unit.
Old Apr 27, 2007 | 07:16 PM
acs-3's Avatar
acs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond reputeacs-3 has a reputation beyond repute
Anyone can explain differences between Gateway 100, 200i, 300, 500?
http://www.dension.com/icelinkgateway500.php
Thx!
pilotscottb
Sep 1, 2015 10:29 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
VGLNTE1
Aug 24, 2015 12:23 PM
