evo cam and piston help
Old Mar 2, 2007 | 12:00 AM
z8cw's Avatar
z8cw is infamous around these parts
Guys,
I apologize for the questions but I really need to get moving. Evoms seemed really backed up, so I am turning to my trusted friends on this forum.
Would anybody know the specs on the Evoms pistons and cams for the 996tt. I bought the forged pistons and need to know if the specs are identical to the OEM or what the clearance valve to dome at TDC would be. I am considering new cams and the cams advertised on the EVO website but can' get the specs on them.
And since I am at it, could you help me with what size the GT700 kit's injectors are and at what HP they would they top out?
Thanks for all your help
CW
Old Mar 2, 2007 | 12:23 AM
sy996tt's Avatar
sy996tt is infamous around these partssy996tt is infamous around these parts
Originally Posted by z8cw
Guys,
CW
ill be at EVOMS in the am.. pm me your info, and ill hopefully get some answers for you ... they are slammed right now...but that will be fixed soon!
sonny
Old Mar 2, 2007 | 12:56 AM
z8cw's Avatar
Sonny thanks...
Old Mar 2, 2007 | 01:44 AM
cjv's Avatar
cjv
Moderator
Guys,
CW
Do you have the parts in your possession?
Old Mar 2, 2007 | 02:05 AM
z8cw's Avatar
Pistons so far...
Old Mar 2, 2007 | 08:55 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
Guys DONT cal EVO just cal Stephen at Imagine Auto. Hell take care of you and knows there stuff just as well. Call him up 913 310 9927 PORSCHPHD CHIME PLEASE!
-Suman
Old Mar 2, 2007 | 09:21 AM
PorschePhd's Avatar
Your builder can assemble the motor and know that the sizing is correct. I can assure you with the combo used you are fine as long as the head is milled and the new HG is installed. This is nessasy for the cams to be used. The actual spec from Evo on the cams will not be disclosed.
The proper way is to trust no one and measure everything out and recheck the measutrments.If you are going to make 800 then you need to change the fueling system again in the car.
Old Mar 2, 2007 | 09:33 AM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
Just like I used to tell people when I had my shop, the only way to find out cam specs is to buy a set..... and even then you only got the "secret" cam if we were doing the entire engine...
Old Mar 2, 2007 | 10:48 AM
z8cw's Avatar
Stephen,
Thanks...
So is the evo HG thicker to accomodate an aggressive lift of the cam?
Old Mar 2, 2007 | 02:19 PM
PorschePhd's Avatar
It is thicker for several reasons but yes.
Old Mar 2, 2007 | 10:14 PM
I may be wrong but I recall over reading that evoms uses gt3 exhaust cams...
I dont think that they change the intake side... I may be wrong.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Mar 2, 2007 | 10:30 PM
PorschePhd's Avatar
Correct. I actually have intake cams as well Sorry no HP data at the moment.
Old Mar 2, 2007 | 10:44 PM
DERBOOST's Avatar
Stephen, are cams a must when hitting the 800 hp level??
OH, thanks for the next day on the WG 1bar actuators.....
Old Mar 2, 2007 | 10:49 PM
PorschePhd's Avatar
You are weclome.
No, they are not. But it doesn't hurt.
Oct 2, 2015 02:23 PM
leevg
New Member Introductions
Sep 28, 2015 05:59 PM
