BLACKED OUT headlights?
Old Jan 16, 2008 | 09:33 AM
  #91
Turbochris's Avatar
Turbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond repute
Looks great on a black car......don't think it would look right on mine.....
Old Jan 16, 2008 | 09:51 AM
  #92
BMWDEMON's Avatar
BMWDEMON is a jewel in the roughBMWDEMON is a jewel in the roughBMWDEMON is a jewel in the rough
good to see that this actually went somewhere...now that I am back in the M I obviously not worried about it but would like to see some results on your cars!
M
Old Jan 16, 2008 | 10:28 AM
  #93
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
Originally Posted by Gary in BR
I have had my lights tinted for 2 years and there is absolutely no purple or moisture issues. If I have to replace the tint every 3 years or so it only takes about an hour for both lights.
I like this...and it has the plus of being "cheap" and "easy to remove"...that is huge for me. It look great. Please share your thoughts on the fogs....how much can one see with the tint on (what tint is it?).
Thanks. Looks great, less billing.
Jeff
Old Jan 16, 2008 | 03:40 PM
  #94
Gary in BR's Avatar
Gary in BR is infamous around these parts
Jeff
They are cheap and easy to remove. And you can vary the tint. At one time I had the dark tint like now but had the lighter tint on the fogs. It looked good (no pictures sorry) and worked just fine. I tried to put a clear film over all of it to seal it in and in that process I ruined the entire tint job, that is why everything is dark now.
The fogs are about useless, I knew that going into it so I replaced the fogs with a yellow bulb. The yellow looks really good. And it helps be be seen. But for a useful purpose the fogs dont have any.
I added another set of lights in my bumper. I've included pictures of the yellow fogs with my yellow "city lights" and my lower lights.
The switch for the lower lights is a foot well switch from a 996 so it looks oem.
Old Jan 16, 2008 | 06:31 PM
  #95
Trevor Ely's Avatar
Trevor Ely is infamous around these parts
I was referring to the "smoked" films, as in Lamin-X or similar films, not spray-on tint when I mentioned the purple hue....and sometimes it even appears yellowish...
Also, the condensation comment was referring to when you remove the lenses from the headlight housing. Lots of times, it's near impossible to create a completely water tight seal again, thus letting moisture inside the housing.
Old Jan 17, 2008 | 06:32 AM
  #96
Awesome stuff....thanks.
Are you saying that the fogs stink without any film...I tend to agree....
Or, did the film take the "decent" fog function and destroy it.
I think I might try to do what you did before the failed clear covering it all....
Was this stuff hard for a tint shop? Did you do it yourself....if so, was it hard? I have never "tinted" and have only seen it done a few times (mostly on tuner tv shows on the Speed Channel....).
TIA
Old Jan 17, 2008 | 08:44 AM
  #97
Gary in BR's Avatar
TIA
The film took decent fog and destroyed it. That is why I just went with a yellow light.
I did it myself.
I removed the lights went inside the house and applied the entire film. The film from stickercity comes precut for our lights. After removing all of the air and water bubbles I could I sat the lights outside in the sun for a few hours and ended up letting them cure about 24-30 hrs.
After I got around to reinstalling the lights I went to wal-mart bought a hobby knife and trimmed out the beam section. It was very easy I did it myself. And as I stated before I have had them for about 2 years with no problems at all.
No purpling no moisture no peeling I recommend this mod.
I was thinking about the purpling and on some of the tints I have seen that cover the low beam I have seen them purple. Perhaps the purple effect has something to do with the quality of the film and possible light source.
Old Jan 22, 2008 | 01:11 PM
  #98
evo911's Avatar
evo911 is a jewel in the roughevo911 is a jewel in the roughevo911 is a jewel in the roughevo911 is a jewel in the rough
Just an update, Dave has my headlights now. He started painting them. Trying different variations, I will post as soon as i have pics. Should look hard *** hell...
Old Jan 22, 2008 | 01:12 PM
  #99
evo911's Avatar
Dave could do color matching that would be interesting to see?
Old Jan 22, 2008 | 02:54 PM
  #100
djomlas's Avatar
djomlas is infamous around these parts
i opened a set of litronic lights...very simple, takes about 25 mins per light...
then you just reseal it...
i dont see why you would pay anyone even a dollar to do this, preheat your oven to 200 degrees, pop in the headlight for 20 mins, pull it out, and pry off the plastic cover, that is all....you just have to be not stupid enough and yank it too hard and break it, if its not going easily, put in oven for few more mins and that should do it.
i have one painted black on the inside, the spare one...havent tested it on the car yet. i used high temp flat black paint
Old Jan 22, 2008 | 03:31 PM
  #101
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
djomlas, so you have done the inside of the housing, not the lens?
This is what I was looking for, anymore pics my friend?
Old Jan 22, 2008 | 04:18 PM
  #102
djomlas's Avatar
yeah i painted everything inside black, well everything but the projector part of the light...
the spare one that i have has a cracked lens tho, but i could get pic of it installed on the car once it gets warmer here in chicago, its snowing out
Old Jan 22, 2008 | 08:16 PM
  #103
v35's Avatar
v35
v35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond repute
looks cool, curious to see how it looks painted.
Old Jan 22, 2008 | 09:05 PM
  #104
Trevor Ely's Avatar
Post some pictures, I'm interested in seeing how this turned out.
Old Jan 22, 2008 | 09:27 PM
  #105
Mr.Al's Avatar
Mr.Al is infamous around these parts
Did I miss the pic of what this looks like with an inside color ( other than black) matched to the car color??? Thought I saw one in yellow???
