Technical gurus: type 2 (over-revs)
Old Jul 22, 2007 | 11:11 AM
wross996TT's Avatar
Hey fellow speeders...I have a link to this thread on Rennlist regarding type 2 (otherwise known as over-revs) ignitions. What do you all think? Can we get type 2's by beating the rev limiter on the way up? Does this make them less significant?
Rennlist thread
Old Jul 22, 2007 | 02:45 PM
tom kerr's Avatar
Rennlist thread
I do this same thing with my car and it never gave me a type2 over rev??
I would love to hear an explaination as I would learn something from this!!
Old Jul 22, 2007 | 03:14 PM
Turbo Fanatic's Avatar
If you own a TT, you've bounced off the limiter. Period.
Is it possible that your car is still accelerating slightly and pushes past redline for 25 ignitions? That's not that many at 6500 RPM. Unless my math is totally off, that's 8/100 of one second.
What's an ignition cycle?
1. a full turn of the crankshaft? I think That's 3 ignitions....
2. once cycle of ignition for all 6 cylinders? 2 turns of the crank...
3. just 25 sparks?
Either way, it's a minuscule number. I've heard the TT heads are good to 7400 RPM, with some tuners programing a 7200 RPM redline. I'm pretty sure hitting 6550 RPM for a few turns of the crank is not catastrophic.
Old Jul 22, 2007 | 07:35 PM
mmmmm's Avatar
mmmmm is infamous around these parts
Must have been on a very steep downhill.
Old Jul 22, 2007 | 08:08 PM
unvmy996's Avatar
i think u get valve float anything passed 7200 rpms.
Old Jul 22, 2007 | 08:36 PM
MidnighTT's Avatar
MidnighTT is infamous around these parts
Wross, no flame intended at all, but doesn't my testimony mean anything? I had 9 type 2 counts. I bounced off the rev limiter hard after breaking traction at the top of 1st gear. Now I have 21 type 2 counts. I posted a Durametric screen shot showing that the most recent type 2 event was in the last hour of engine operation. Nobody else drove the car in that hour, and I will swear on whatever religious object you'd like that I did not blow a downshift in that last hour. I did, however, slam against the rev limiter (6750 according to Kevin @ UMW).
Why is this hard to accept?
Jeff
Old Jul 22, 2007 | 08:47 PM
wross996TT's Avatar
Jeff
Jeff, sorry if it sounded negative. I am truly trying to learn something here. I absolutely believe your testimony!!! I was just trying to get an explanation from the others on the forum (guys that know way more than me) since I have always been told that type 2s were from missing a shift. Then I was asking if perhaps type 2s were not as bad as most have been led to believe. Just after more info.
Peace
Old Jul 22, 2007 | 10:15 PM
What's the RPM limit for a type 2 over rev? It's not hard to imagine that the car is still acclerating for a split second (we're talking x/100 of 1 second here) when hitting the limiter.
Old Jul 23, 2007 | 10:31 AM
WOODTSTER's Avatar
I can tell you that the valves are happily doing their deeds at 7200 RPMs' as
I have run mine up to 7200 a couple of times...
MK
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
TOGWT
Detailing
Oct 1, 2015 07:59 AM
00aston
Sep 28, 2015 08:08 AM
