Stiff Clutch Pedal
Old Jul 29, 2007 | 03:29 PM
usarugger's Avatar
usarugger is infamous around these parts
Stiff Clutch Pedal
My car often has a stiff clutch pedal. The pressure varies during the driving, and is quite stiff at startup. Does anyone know if this is normal or what the remedy might be?
E.
Old Jul 29, 2007 | 03:30 PM
mambodave's Avatar
mambodave is infamous around these parts
My 03tt had the same problem, Dealer replaced the accumulator and it went away...
Though I actually like a stiffer clutch.
Old Jul 29, 2007 | 03:37 PM
usarugger's Avatar
What did the repair cost you?
Old Jul 29, 2007 | 05:01 PM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
Check the fluid..you could just be low.
Old Jul 29, 2007 | 07:35 PM
mambodave's Avatar
$400 i think.
Old Jul 29, 2007 | 08:50 PM
Turbo Fanatic's Avatar
Ditto, same here. It's much softer when the car is on right? I think it was like $250 for me....
You may also hear a whinning sound from the engine compartment (power steering pump is connected to clutch) that goes away when you depress the clutch...
Old Jul 30, 2007 | 12:23 AM
usarugger's Avatar
What would happen if someone had put the wrong fluid in the power steering reservoir? Would that then affect the clutch since they are connected? How are they connected, there are two separate reservoirs??
Old Jul 31, 2007 | 12:12 AM
ezmoney888's Avatar
ezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond repute
accumulator. I had one replaced under warranty. Only happened at start up.
Old Jul 31, 2007 | 10:12 AM
cohare's Avatar
cohare has a spectacular aura aboutcohare has a spectacular aura aboutcohare has a spectacular aura about
Would this cause a leak? I have a slow leak in the driver's side front that the dealer couldnt locate (morons), and I have a stiff clutch petal.
Old Jul 31, 2007 | 03:02 PM
digitekkz's Avatar
digitekkz is infamous around these parts
so if the clutch is stiff in the morning before I start the car is it still the accumulator?
Old Jul 31, 2007 | 03:56 PM
SlowMotion's Avatar
SlowMotion is infamous around these parts
Being stiff in the morning is a healthy thing... don't worry about it
Old Jul 31, 2007 | 06:26 PM
wross996TT's Avatar
I thought you wanted it stiff at night
Old Jul 31, 2007 | 08:30 PM
SlowMotion's Avatar
I'm on the theory its whatevers clever.
Old Aug 1, 2007 | 01:01 PM
digitekkz's Avatar
hahah yall totally just change the subject I was asking about. But to comment to that I am stiff both at night and in the morning. But that is okay I have two differents techs to take care of that.
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
sparks
Sep 8, 2015 03:03 PM
falter
964 Turbo
Sep 4, 2015 01:41 PM
falter
964 Turbo
Sep 4, 2015 01:37 PM
