Procedure to eliminate the malfunction light from the spoiler.
Old Aug 16, 2007 | 06:33 PM
landjet's Avatar
bm3r, sounds like everything is working in your case, and the light does go out, so, I would be thankful it's not worse.
Old Aug 16, 2007 | 06:46 PM
USCTrojanMan29's Avatar
USCTrojanMan29 is infamous around these parts
Originally Posted by PorschePhd
You can also buy the aerokit harness for like 75.00 which also takes care of the issue.
Interesting...I'm in the process of installing the GT2 decklid/wing and this is probably something that I should get...what's the part #?
Old Aug 16, 2007 | 09:21 PM
bm3r's Avatar
bm3r is infamous around these parts
thanks for the info! it's just odd that the light is on when I start the car, then it comes off ONLY after driving it...oh well. Im thankful it's not broken!
Old Oct 4, 2007 | 12:32 PM
Lazerblade's Avatar
Lazerblade is infamous around these parts
Originally Posted by Pierre996TT
I have seen a lot of people asking for the same question:
"How to eliminate the malfunction light from the spoiler."
In my case I do not want the wing go up anymore, others just want the GT2 deck and no this annoying sound and light.
I have done some search on the board (Porsche PhD) and it seems that there is a cheap and simple way:
1.- Unplug the harness on the right side of the engine deck.
2.- If you look at the harness from the rear, with the lock at the top:
a) Start at the bottom row:
i. thick brown and thick black = fan motor
ii. next to them a thin red/blue and brown/red =lamp
iii. next is a single thin wire for brake light power
b) top row:
i. BLANK,
ii. then first is a single wire for the brake light(signal),
iii. next a green gray spoiler switch wire,
iv. next yellow/green thick spoiler motor (positive) ,
v. next thin gray/brown spoiler switch,
vi. Last thick green/blue (ground) spoiler motor.
3.- Unplug the thick green/blue, by pulling it out of the harness (ground for motor), Tape it up.
4.- Then connect gray/brown with a spoiler power thick yellow/green.
5.- No light no hot spoiler motor wires.
6.- You can remove the spoiler switch bottom from the dash if needed.
I am putting a stationary wing on my 2001 C2 tonight. Is this what I need to do to keep the light off on my dash? Or, is this only good for TT's?
Thanks,
Paul
Old Oct 4, 2007 | 05:02 PM
rafiki's Avatar
rafiki is infamous around these parts
another with increasingly present malfunction light.
Old Dec 26, 2007 | 10:45 AM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
so where do we buy the aero wiring harness for $75 please
Old Feb 24, 2008 | 01:16 PM
996TurboOnMaui's Avatar
996TurboOnMaui is infamous around these parts
+1
Old Feb 24, 2008 | 01:35 PM
silvershark's Avatar
silvershark is infamous around these parts
Thumbs up
Originally Posted by 996TurboOnMaui
+1
+2
Old Feb 25, 2008 | 07:30 PM
Worked for me. After completing the wiring switcheroo, I started up the engine the I got a "Spoiler Malfuction" message. It hasn't reappearred. Hopefully it stays that way.
Old Feb 25, 2008 | 07:42 PM
DYL 911's Avatar
DYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to all
interesting, my wing was working (manually) even with the light but now I can't seem to get the spoiler to go up anymore. it does not flip up automatically while speeding. i checked out the pumps and even after making sure everything was working right it seems to simply not work even manually now. i think i'm gonna do the trick wiring and install a GT2 lid
Old Feb 26, 2008 | 07:11 PM
Okay... I thought all was fine with the wire swapping until I hit the magical 75 mph today and a wonderful beep and "Failure Spoiler Control" message along with the little red spoiler light glared at me on the dash. When I restarted the car, the message and light did not reappear. I'm taking it for granted that they will reappear once I hit 75 mph again. Am I doing something wrong?
The only step I didn't understand on the OP's instructions was step 5:
"5.- No light no hot spoiler motor wires."
I didn't understand it so I didn't do it. Is this where I went wrong?
TIA
Old Feb 26, 2008 | 07:28 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
Fot the TT, get the aero Kit harness....At the dealer and its under $80.00
For all other 996, you can get the GT3 rear wiring harness...AT the dealer , last one i bought was $ 63.00
Old Feb 26, 2008 | 07:39 PM
I'm such a penny pincher. Oh well...if there's no other way.
Old Feb 26, 2008 | 09:31 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
I just pulled the wires and tied them together and taped up the hot ones. Theres no reason to spend money on a harness just to put a couple wires together.
Old Feb 26, 2008 | 09:43 PM
My problem is that I tried the OP instructions with the exception of step 5 and still get a malfuction light when I go over 75. Can someone interpret step 5 for me? Thanks.
