wastegate adjustment
Old Aug 8, 2007 | 04:45 PM
mambodave's Avatar
mambodave is infamous around these parts
Any DIY posts with pics on watsegate adjustments? Im getting flashed tomorrow and want to take it on tomorrow afternoon.
Old Aug 8, 2007 | 09:30 PM
Bodybag's Avatar
Bodybag has a spectacular aura aboutBodybag has a spectacular aura about
You don't need pics, they won't help. Make (or buy) a pressure tester and set them so they start to crack open the WG's when you apply 12psi to them. This will get you a solid 1.1 bar with an occasional 1.2 spike.
They MUST be adjusted by pressure to assure they are exactly matched. There is no way to adjust them properly just by using the "number of turns" method.
FWIW, I made a real good pressure tester from an old boost gauge, a hand held bicycle pump, some vac hose and "T" fitting.
Old Aug 9, 2007 | 02:11 AM
wross996TT's Avatar
Getting flashed, but what turbos do you have? Stock wastegates or better springs?
Old Aug 9, 2007 | 08:43 AM
WOODTSTER's Avatar
Bodybag,
great advice, otherwise you are just pissing in the wind.
MK
Old Aug 9, 2007 | 12:32 PM
mambodave's Avatar
stock turbos and wastegates.
I noticed a significant difference. getting 1.1 fairly easy after the flash.
Old Aug 9, 2007 | 04:35 PM
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
X50 turbos (K24s)? ..... if so you neeeeeeed new WG's
Old Aug 9, 2007 | 07:27 PM
mambodave's Avatar
no x50 here..
Old Aug 10, 2007 | 01:05 AM
wross996TT's Avatar
Then you don't need the adjustment. Any more than 1.1 on K16s is a total waste.
Old Jun 8, 2010 | 05:10 PM
Merlin's Avatar
Merlin is a glorious beacon of lightMerlin is a glorious beacon of lightMerlin is a glorious beacon of lightMerlin is a glorious beacon of lightMerlin is a glorious beacon of lightMerlin is a glorious beacon of light
Understand I can do this myself. Where can I get a pressure tester?
So when you pull the hose off the WG, and put the pressure guage/hose on it, apply air, how can you tell it cracked open? Can you hear it? or does the guage pressure just drop?
Thanks,
Old Jun 8, 2010 | 05:25 PM
Thanks,
you look at the arm and rod moving...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 8, 2010 | 05:38 PM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
i've been some doing some learning and work in this area as of late. one thing to note. Tested the stock actuators, the arm/flap start moving at 0.35-0.4bar. I suspect it's the boost solenoid n75 (controlled by DME) that limits pressure to the actuator, allowing higher bar pressures. With out flash and exhaust, my car went from 0.6 to 0.8. after flash .8 to 1.0. didn't touch the wastegate. That said, using a 1bar actuator should stablize boost under 1bar, because the solenoid wont have to compensate (but really not necessary IMO 1bar and under). think this is how this works, please correct me if Im wrong.
+ 1 on using an airsource to manually test actuators at diaphram. not that hard to do, just need the right tools.
Old Jun 8, 2010 | 06:07 PM
ard's Avatar
ard
I put one hand on each side and can feel the arms starting to move much more accurately that you can see then move. Better yet when you have the exhaust off, you can put a finger on the round wastegate cover and just sense when it cracks loose.
A
Jeanmarcboilard
Sep 22, 2015 05:03 PM
johnny.dangerous
Sep 14, 2015 02:19 AM
