Cant seem to Solve The PSM and ABS Problem
Old Sep 10, 2007 | 08:03 AM
Terence's Avatar
Terence is infamous around these parts
Angry Cant seem to Solve The PSM and ABS Problem
Hi guys .. need some help here.....
i have a 2001 996 TT with the PSM and ABS lights lighting up after driving for a few mins and this happen when i hit the brakes .when this happen the idling goes irregular.i brought it to the tech guys and they have change the o2 sensors,abs sendors ,the hoses to the divertor cause there was a leak in it..and the Maf sensor ... and i thought it was the end of my problems ...so after collecting the car drove for a few mins ... the lights of both PSM and ABS light up again....rpm goes irregular again.
can anyone give some advise on the issue... i am really confuse
Old Sep 10, 2007 | 08:14 AM
wross996TT's Avatar
Did you actually get the codes read? Do this and give us the numbers. Did they do a pressure test...sounds like a leak. If not when were the plugs changed...or coil packs may be cracked.
Old Sep 10, 2007 | 07:42 PM
Terence's Avatar
the tech guys have done a leak test and thats where they change the hose for the divertor area. reading the codes does not help cos every time shows not fault once the engine is restarted..
by the the way what plugs are u refering to?? and what a coil pack??? could u enlighten me... how does the maf works .. does have sensors... i need to learn... cant let these tech guys tell me bull when it comes... around.
Can i ask is it true that the brake switch affect the PSM ABS... when i brake the lights do come on... as usual ... but strange think is that when i brake the psm and abs do lght up too.. and rpm goes irregular ..so what do u think... is that switch a problem????
Old Sep 10, 2007 | 07:54 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
I had a similar problem with the ABS and PSM lights on. My shop couldn't figure it out for several days. They replaced the throttle body and that solved it.
Old Sep 10, 2007 | 08:45 PM
Terence's Avatar
sorry what a throttle body??? how does it affect the psm and abs???please advise
Old Sep 10, 2007 | 10:19 PM
wross996TT's Avatar
Terence, if you threws codes they do not "go away" by restarting the car....you need to have them hook up the PST2 or PIWIS tester and read the codes THAT ARE STORED in the ECU.
Spark plugs....when were they last changed? Get
Bosch FR6 LDC
Ignition coils...they sometimes crack.
Hot-film MAF sensors use a centrally-heated film element. These sensors function on the electrical principle that resistance increases with temperature. As intake air moves past the film, the cooling effect causes a measurable drop in resistance, and thus lower voltage is required to maintain the prescribed temperature. The MAF control unit is sent a reference voltage of 5V, and returns around .4V to.5V at idle and from 4.5V to 5V at full throttle. Based on a fixed data set, an accurate assumption of air mass is made. This information is sent to the ECU for appropriate adjustments to timing and AFR.
Terence, We really need to codes to help much further. ABS/PSM are just idiot lights that can mean many things.
My guess on throttle body change as posted above is it was cracked and therefore leaked.
Old Sep 11, 2007 | 01:25 AM
Terence's Avatar
Smile
thanks a million for your pro advise... sorry . do be patience with me as i am new to this... i will try getting the codes from the tech guy that is working on my car..but at the mean time ... if u have any more possiblities on what maybe the cause to the problem PLEASE let me know.. cos my tech guys are cracking their heads at this moment.. t...
Old Sep 11, 2007 | 05:48 AM
Terence's Avatar
hi guys ..have a question for you as u know my psm an abs has lights on.. is it normal for the rpm to be irregular as well.. its like hunting everytime when its comes to a stand still or even whenthe car is gliding down a slope .
can u guys name the areas that i should look into when i see my yech guuys i know it sound crazy but few heads are better than one..
as mention by Wross996TT
1. Maf
2. Ignition coil
3 Plugs Borsh Fr6 LDC
4.throttle body for leaks
5.
6.
this will be a get help soi can hightlight the possible areas to check..
Old Sep 11, 2007 | 11:35 AM
Onetime's Avatar
I'll find out what the problem was with the throttle body and get back to you.
Old Sep 11, 2007 | 06:01 PM
Turbochris's Avatar
Turbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond repute
This happened to me too......if it ONLY triggers the PSM and ABS lights on the dash as SOON as you hit the brakes.....it's the little brake light sensor behind the brake lever....took about 15min to replace and was like $25.
Chris
Old Sep 11, 2007 | 06:02 PM
wross996TT's Avatar
Chris
No way that would effect how the car runs and idles....do we have another guess before the codes are read?
Old Sep 13, 2007 | 12:40 AM
ezmoney888's Avatar
ezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond reputeezmoney888 has a reputation beyond repute
Picked up my car from the dealer today for a PSM/ABS light issue. It was a simple fix...the brake light sensor was not working. I had no problems with power loss. Just everytime I started the car and pressed the brakes the lights would show. Anyway, it was $168 to fix and it was covered by my total shield extended warranty.
Old Sep 13, 2007 | 12:55 AM
Terence's Avatar
Cool
but how did you know that it was the brake switch... were your brake lights working as in lamps were they lighted once u press the brakes or was it not before you change the switch.....any idea?? cos mine has the problem when i m on the road slowing down.. thats when i press the brakes.. it shows psm abs....please enlighten me.
Old Sep 13, 2007 | 11:09 AM
ezmoney888's Avatar
I guess there is a sensor behind the brake pedal that when you push it the brake lights turn on. Well, my brake lights were not turning on when I pressed my brake pedal and that was the problem.
Old Sep 13, 2007 | 11:16 AM
kd126500's Avatar
kd126500 is infamous around these parts
Brake switch
"This happened to me too......if it ONLY triggers the PSM and ABS lights on the dash as SOON as you hit the brakes.....it's the little brake light sensor behind the brake lever....took about 15min to replace and was like $25."
Same here. Fortunately Sharkwerks looked at the codes and knew where to look for the problem. It is a small cheap plastic brake switch behind the pedal.
BLKMGK
Sep 19, 2015 03:51 PM
dgreen78
Cayenne 955/957
Sep 12, 2015 11:44 AM
flewis763
Sep 10, 2015 01:08 PM
