Help with headlights
Old Sep 23, 2007 | 05:55 PM
dmilzoff's Avatar
dmilzoff is infamous around these parts
Recently, my headlights do not always go on when I turn the switch. I need to switch back and forth 3 or 4 times to get them on. I took out the switch in hopes of spraying contact cleaner on the switch, but it is a sealed switch with very limited access.
Tonight, with my headlights on, I turned on the bright lights and ALL lights went out. That was a trip.
Can I be sure that it is the switch and not the ignition switch? Where is the best place to buy a switch? I can install it.
David
Old Sep 23, 2007 | 06:08 PM
stefenolsen's Avatar
stefenolsen is infamous around these parts
Switch
Sounds like the switch to me. You can probably test the switch before you buy a new one.
Old Sep 23, 2007 | 06:12 PM
dmilzoff's Avatar
How? The problem is sporatic. I'm ready to buy one if I need it but I hate buying something to find out it was the wrong part.
Old Sep 23, 2007 | 08:02 PM
mtesh73's Avatar
mtesh73 is infamous around these parts
i would think the best way to test the switch for electrical continuity would be with a voltmeter, you can check both continuity and resisitance with a multimeter available mostly anywhere.
Old Sep 23, 2007 | 08:11 PM
slant911's Avatar
slant911 is infamous around these parts
I've read about this issue several times and seems to be fairly common. Always turns out to be a bad headlight switch.
Old Sep 24, 2007 | 07:27 AM
porschedude996T's Avatar
porschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really niceporschedude996T is just really nice
Common as in it happens, not common like it happens all the time to everyone and it returns in short order... My 2 cents
Old Sep 24, 2007 | 12:20 PM
SEAN 996's Avatar
SEAN 996 is infamous around these partsSEAN 996 is infamous around these parts
David
I just dropped my p-car for the same symptoms except, the low beams no longer come on. I tried replacing the lights but that didn't work. The other lights still work. I' ll know more later.
Just got a call back from the shop and it's the switch.
Old Jul 17, 2008 | 09:38 PM
GT650-25's Avatar
GT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant futureGT650-25 has a brilliant future
how do you replave the switch? can it be done or dealer only? cpo covers this?
DYL 911
Oct 20, 2025 05:08 PM
adnanm3
Oct 25, 2016 08:38 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
DYL 911
Oct 1, 2015 02:47 PM
ECS Tuning - BMW
Sep 29, 2015 01:18 PM
