Help, Trunk won't open!!
Old Jul 31, 2008 | 07:56 PM
fastbydrmike's Avatar
fastbydrmike is infamous around these parts
Hey guys, my trunk sounds like it is trying to open when I hit the switch but it will not release. I have been having trouble with it the last month or so. Sometimes it works and sometimes it doesn't. I have things in there I need to get out. Is there a manual overide next to taking a hammer to it(**&#%!!!)?
Thanks,
Mike
Old Jul 31, 2008 | 08:34 PM
jpclinging's Avatar
jpclinging is infamous around these parts
Try the manual release located in the door jam on the passenger side, right beside the upper hinge. Pull it out and the hood should release.
Old Jul 31, 2008 | 09:34 PM
Svoruz's Avatar
Svoruz is infamous around these parts
Isn't that the manual release for the fuel door?
I had the same problem a couple of week ago. I basically pressed down on the hood like I was giving CPR chest compressions while I had my son hit the release button. I guess you could hit the release on your remote as well. Then search for hood release adjustment procedure.
Old Jul 31, 2008 | 10:11 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
You are right, that is the fuel door release, the manual release is behind the passenger headlight, you can get to it by partially removing the right front fender liner, or if your lucky can fish it out from behind the headlight with a hooked wire, but you are kind of shooting in the dark, especially if its fallen down as it is usually taped up to the body.
Old Aug 2, 2008 | 04:01 AM
I did a search and one answer was to drive it around the block which I did and it opened but when I closed it, it would not open again. So does this mean I need a new part or need to grease the release or what. I tried to find the cable behind the head light and no go on that.
Thanks,
Mike
Old Aug 2, 2008 | 10:23 AM
Svoruz's Avatar
It may need to be replaced but more than likely it probably just needs adjusting.
There is a very good procedure for this on R'tech by Viper501.
Old Aug 2, 2008 | 10:33 AM
LowStro9's Avatar
LowStro9 is infamous around these parts
The bonnet release cable is located behind the rear passenger headlight housing and is accessible by slipping your hand behind the inner fender liner of the front side of the passenger tire......at least that is where mine is.
Old Aug 2, 2008 | 10:52 AM
raffi's Avatar
raffi is infamous around these parts
Thanks,
Mike
the 996's were notorious for this problem, you have the manual release right (prefacelift) the electronic is different.
when i had this problem the only solution was to pull up on the hood with a coat hanger or something protected with towels, while someone is pulling up on the manual release.
the springloaded device fails because the metal coil gets old and comes out of place.
the5
Oct 14, 2015 06:46 AM
Korntera
Sep 15, 2015 08:20 PM
lokmeup
Sep 9, 2015 09:24 PM
JSF721
Detailing
Sep 8, 2015 07:57 AM
katyrow
Sep 7, 2015 10:17 AM
