Blinking temperature light?
Old Mar 11, 2009 | 08:51 AM
spmorgan's Avatar
spmorgan is a jewel in the roughspmorgan is a jewel in the roughspmorgan is a jewel in the rough
My (new to me) 1999 C2 Cab will, during spirited driving, start blinking the temperature light at me. The manual says that it could be low coolant or overheating. The temperature seems to stay in the 180-190 range, so it doesn't seem like it is overheating, and I had my tech top off the coolant level the other day, but it did it again after the top off.
It only blinks for a few minutes, and then goes off again.
Anything to worry about?
Shawn
Old Mar 11, 2009 | 10:49 AM
Jam996's Avatar
Jam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud ofJam996 has much to be proud of
It is low coolant, most common problem with this is the tank its self has a leak or cap needs to be changed.
Old Mar 11, 2009 | 10:52 AM
pszikla's Avatar
pszikla is infamous around these parts
Shawn!
Usually not something to worry about on the older models.
You will find many posts about replacing the cap on the coolant tank which were often defective.
I believe one indicator of the caps that go "bad" is the part number incl. "00" written on the cap.
pete
Old Mar 11, 2009 | 11:11 AM
c4swat's Avatar
c4swat is infamous around these parts
THATS PRETTY FUNNY I HAD THE SAME THING HAPPEND TO ME LAST NITE..BUT THERE IS ALSO SMOKE COMING OUT OF THE EXHAUST..
Old Mar 11, 2009 | 11:22 AM
pszikla's Avatar
if the smoke (whitish, sweet smelling) only lasted a short time, then it is probably coolant that spilled out of coolant tank onto drivers side exhaust pipes.
If continuous..........better have it checked!!
Pete
Old Mar 11, 2009 | 12:11 PM
c4swat's Avatar
THANKS PETE I HOPE THATS IT..THERE WAS ALOT OF SMOKE. I SPOKE WITH MY TECH AND HE ADVISED ME THAT IT COULD HAVE BEEN THE WATER PUMP THAT TOOK A DUMP OR SOMETHING ELSE I HOPE ITS THAT AND NOTHING ELSE..
Old Mar 11, 2009 | 12:16 PM
spmorgan's Avatar
Originally Posted by pszikla
Shawn!
pete
I bet the cap is the problem. Thanks for pointing me in the right direction!
Shawn
Old Mar 11, 2009 | 12:33 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Of course this is also the first usual symptom of an intermix problem. Check your coolant tank to see if there is any evidence of oil (the coolant will look like mayonaise) and then check the oil to see if there is any evidence of coolant ( the oil will llok like chocolate milk). For both of your sakes I hope it is just a bad cap or a cracked cooant tank, which are both common problems.
But for those of us who have experienced an intermix problem, it ssems these problems are far more common than they should be.
Good luck, I hope your problems are simple low cost caps or tanks. Keep us posted.
Old Mar 11, 2009 | 12:57 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
Coolant level is NOT the only cause of a blinking temp light. If your engine compartment gets too warm, it will flash exactly the same. Check your fan operation.
Old Mar 11, 2009 | 02:27 PM
c4swat's Avatar
thanks for all the help guys..if it was a intermix problem what is the solutionto fix that.
Old Mar 11, 2009 | 03:05 PM
himself's Avatar
himself is a jewel in the roughhimself is a jewel in the roughhimself is a jewel in the rough
-td
Old Mar 11, 2009 | 03:19 PM
c4swat's Avatar
sounds good.....
Old Mar 12, 2009 | 03:43 AM
quickness402's Avatar
quickness402 is infamous around these parts
wish you the best in finding out the problem
Old Mar 13, 2009 | 01:21 PM
luva966tt's Avatar
luva966tt is infamous around these partsluva966tt is infamous around these parts
My 996 would blink when the fluid got low, I finally had to replace the accumilator
GSR Autosport
Aug 26, 2015 05:20 PM
PelicanParts.com
Aug 26, 2015 04:25 PM
PelicanParts.com
Aug 26, 2015 04:24 PM
ECS Tuning - VW
Aug 21, 2015 09:11 AM
