How to wire Factory Bose rear Subs
Old Feb 23, 2011 | 07:13 AM
GMendoza's Avatar
GMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of light
What's the best/easiest was to install and wire the factory rear subwoofers on a car that didn't come with rear subwoofers. Also, would rear subs from a 997 work on a 996?
Thanks in advance.
Old Feb 23, 2011 | 10:53 AM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
If you did not have the rear subs then you probably don't have the HiFi system or the Bose system with the HAES amp. To power rear subs you will probably need an amp as you need outputs that have only the lower frequencies to feed the subs. What factory system does your car have and do you have an Amp?
Old Feb 23, 2011 | 03:37 PM
GMendoza's Avatar
Thanks. I thought the stock Bose subs were self powered? My car is a '01 with the stock 220 head unit. I think I have an amp under the front bonnet behind a plastic grill next to where the cd changer mounts. I don't have any Bose badges anywhere though.
Old Feb 23, 2011 | 03:39 PM
GMendoza's Avatar
I do have subs in the door I believe
Old Feb 23, 2011 | 06:21 PM
GMendoza's Avatar
Just like I suspected, this guy has the same sub I have and it is self-powered.
http://www.renntech.org/forums/index...ofer-retrofit/
Any suggestions on how to wire it?
Old Apr 1, 2011 | 12:05 PM
GMendoza's Avatar
The install is complete.
My car did have the stock HAES 6 channel amp wired to two speakers in the dash, two in the quaters and 2 subs in the doors. The stock rear subwoofer has its own amp but needs a subwoofer signal. Also, the sub was stuffed before installation.
So, I made a 15ft loom and tapped it to the stock amp as follows.
B18 - rear sub (+)
B7 - rear sub (-)
A7 - 12v switched
B1 - Ground
B2 - 12v constant
as for wiring at the sub:
A2 + signal from amp
A3 - Signal from amp
A4 switched 12v from amp
A5 Ground connection (this is a brown wire)
A6 12v Power feed (this is a red/ brown wire)
Done!
Old Apr 1, 2011 | 01:01 PM
white99c2's Avatar
white99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of lightwhite99c2 is a glorious beacon of light
I have the same Hi Fi Stereo in my '99 with dash, rear and door speakers powered by the stock HAES 6 channel amp.
Here's my question, can I go buy a Bazooka Powered Sub and wire it into the amp using the same wiring you did?
B18 - rear sub (+)
B7 - rear sub (-)
A7 - 12v switched
B1 - Ground
B2 - 12v constant
Old Apr 1, 2011 | 02:21 PM
alpine003's Avatar
Originally Posted by GMendoza
Clean wiring job but those wires look a lot like home electrical solid copper wiring insulation.
Old Apr 1, 2011 | 08:18 PM
GMendoza's Avatar
It should work although I believe the self powered bazookas' amp has a built on crossover. Not sure what would happen to the sound if you run it through a crossover twice. You may be batter off just tapping the rear speaker wires vs the subs.
Lol. Close, it's stranded.
Old Apr 2, 2011 | 02:20 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
As seen above it looks like you can make it work, but unless you're getting the parts dirt cheap, and wire it yourself, consider junking the whole think and starting with a double din head unit (Pioneer etc) and seperate amp and new speaker. It will sound way better, you get a Nav voice control system mere mortals can use, Blue Tooth, Great Ipod interface, DVD player, USB flash port and a back up camera option for when you go backwards ice racing in Sweden.
Old Mar 23, 2014 | 03:24 PM
sgazard's Avatar
sgazard is infamous around these parts
So I installed:
Pioneer App Radio: http://www.pioneer.eu/eur/products/2...A110/page.html
Active Amplifier bypass: http://caraudiosecurity.com/ct53-po0...system-adapter
Facia http://www.caraudiocentre.co.uk/prod...6-_p-27179.htm
Dash and Rear Speakers: http://www.jmgshop.com/9xx---porsche...akers-62-p.asp
Door speakers: http://uk.infinitysystems.com/produc...ppa-5211i.html
Now struggling with sub wooffer / bass box options.
I have purchased a BOSE original bass (I like the factory look) .....
So questions:
1) I assume I will need an Amp?
2) Can I use the original one? Mine was the original amplified system but I guess now bypassed by the connects2 wiring?
3) What should I buy? Presumably I should then seek to run the other speakers off the amp as well?
Old Mar 26, 2014 | 01:14 AM
yo_clarkie's Avatar
yo_clarkie is infamous around these parts
I have a BOSE equipped car, well it was BOSE equipped but that stuff all in a box now and converted.
I installed an amp where the CD Changer once went and it runs 5 channels, dash, doors and Sub. The head unit rear channel runs the rear seats. I looked at JL, Alpine and Kenwood and choose the Kenwood as it was the best fit in the available space. I used an XR-5S:
http://www.salectronics.com/shopexd.asp?id=1528
If you want one from these folks email them, but plenty of other sources for a few dollars more. Couldn't be happier with it.
You also need to rewire the speakers in the sub to be in series, not parallel. Its fairly easy to do with a soldering iron and a couple of bits of heat shrink.
No idea as to what the factory (non Bose) amp can be used for, but someone along in a min to help I expect :-)
Jun 10, 2017 07:45 PM
r_matt_6
Oct 8, 2015 06:07 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
Aug 19, 2015 06:35 PM
Nissan GTR
Aug 19, 2015 02:11 PM
