Question--My 2002 front end makes a knocking noise
Old Oct 24, 2011 | 03:46 PM
Ersel's Avatar
Ersel is infamous around these parts
When I drive my 2002 for more than 15-20 minutes I notice a knocking sound. It seems to be coming from/related/heard near the front suspension or steering area and more pronounced over little bumps and while driving on streets. When I drive the car the next day, the noise will always go away until the car is driven for a while again. It seems like the sound can be heard behind the dashboard.
When I had it on the rack awhile ago the mechanic didn’t see any issues and unfortunately it wasn’t making the knocking sound when I took him for a test drive. Any ideas what is causing the problem?
Old Oct 25, 2011 | 06:01 AM
JayFunk's Avatar
JayFunk is a jewel in the roughJayFunk is a jewel in the roughJayFunk is a jewel in the rough
tie rods? my inner ones are bad so i gotta replace those soon. also see if anything is loose or rolling around in the front boot. some people have reported there jack or wheel lock was loose and that was causing the noise up front. silly but it happens. good luck!
Old Oct 25, 2011 | 07:56 AM
Dennis C's Avatar
Sounds like worn bushings in the suspension. Is the car a C2 or a C4? AWD cars have some additional suspension components that can wear out as well.
Old Oct 25, 2011 | 10:30 AM
Ersel's Avatar
There's nothing in the boot area rolling around--good question. Again, it is consistent when the rattling starts happening. When the car is warmed-up/driven for more than 15 minutes straight.
It is a C2.
Old Oct 25, 2011 | 11:22 AM
PKStyles's Avatar
PKStyles is infamous around these parts
its your front toe-links. had the same problem. it's a cheap fix, maybe $60 a side and half hour to an hour labour.
Old Oct 28, 2011 | 05:04 PM
Ersel's Avatar
And did you have the same intermittent problem with the clunk noise?
Old Apr 17, 2013 | 12:41 AM
producerjohn's Avatar
producerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud of
Did anyone ever find a fix for this?
Old Apr 17, 2013 | 03:04 PM
Ersel's Avatar
I had my car serviced by the Porsche dealer 2 months ago and have not had the clunking sound for a while. However, I only drive the car 500 miles a year and for short drives. Unfortunately, I have not heard the sound for a long time and the mechanic could not replicate the sound either. So, they were speculating it was some steering thing that would cost me like $500 a side or $1k a pair. I didn 't really believe them since they were speculating so I didn't have it done. I REALLY need to drive the car more and when I do the problem will arrise. Seems like the car needs to get warmed-up and driven at least 30+ miles for the issue to start/be heard.
Old Apr 19, 2013 | 09:58 AM
Ersel's Avatar
Mine is a C2
Old Apr 22, 2013 | 02:29 PM
roadsession's Avatar
roadsession is infamous around these parts
you'll have to replace inner and outer tie rods
Old Apr 23, 2013 | 11:34 PM
tarzancoe's Avatar
tarzancoe is infamous around these parts
Just in case, check that the spare tire is not loose. It would make a clunk noise.
Old Apr 24, 2013 | 07:07 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Just an FYI, you really do need to drive it more. Water will accumulate in your oil and brake fluid.
Old Apr 24, 2013 | 07:57 AM
white out's Avatar
white out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to behold
I had the same issue with my C2. Ended up being the sway bar bushings. They are super cheap and easy to replace. I highly suggest replacing those first to see if they are the cause.
Old May 15, 2013 | 01:17 AM
Bigbiglemoncoke's Avatar
Bigbiglemoncoke is infamous around these parts
hi,
does the knocking noise happen under braking?
Old Aug 8, 2015 | 12:04 PM
boxster0310's Avatar
boxster0310 is infamous around these parts
Question Similar Noise 2003 Boxster
I have a similar situation. A knocking noise coming from what sounds like the front left of my boxster. I only ever notice it when on the interstate and the windows are up. If the radio is on, or the windows are down I guess it's just not loud enough to be noticeable. I never hear it at slower speeds... generally it happens at 60 or above.
It will come and go, but I think that has to do with speed. Have recently had the car serviced... they did a purchase inspection and came back with nothing.
Any suggestions?
I'm posting, as the situations described as creating the noise for this thread are different then mine.
I appreciate any suggestions
2lflat4
Nov 18, 2019 05:05 PM
Enemy
Nov 10, 2015 08:01 AM
Senatorblutarsky
Aug 28, 2015 12:44 PM
ModBargains
Aug 20, 2015 12:28 PM
