creaking up front?
Old Mar 11, 2012 | 07:27 AM
DRKNGHT's Avatar
DRKNGHT is infamous around these partsDRKNGHT is infamous around these parts
creaking up front?
So I have noticed that when I am driving at low speeds I get a creaking sound coming from the driver side front suspension. It also happens when I get in or out of the car. I want to think it is a lower control arm but is there a possibility of something else? Anyone else had this problem? I can push down on the fender and it makes the sound as well. very annoying..
Old Mar 12, 2012 | 01:01 PM
DRKNGHT's Avatar
anyone?
Old Mar 12, 2012 | 05:45 PM
Sneaky Pete's Avatar
Sneaky Pete has a spectacular aura aboutSneaky Pete has a spectacular aura about
Could be the rubber bushing on your sway bars. I would look at refreshing some wear components.
Old Mar 12, 2012 | 05:54 PM
DRKNGHT's Avatar
Refreshing? Could you elaborate?
Thanks man.
Old Mar 12, 2012 | 09:53 PM
996tofast4911's Avatar
996tofast4911 is infamous around these parts
Update wear items... Sway links, sway bar bushings, various control arm pieces, etc....
Old Mar 12, 2012 | 09:58 PM
rrrruben's Avatar
rrrruben is infamous around these parts
Suspension links at the sway bar or control arm generally come together with rubber bushing in most vehicles. Our P-cars would not be that different. The rubber tends to deteriorate over time or abuse. Replace where needed, and always do both sides. A creaking sound (metal to metal, or off center if you will) is the most common hint where a replacement is the remedy. Good luck.
Old Mar 13, 2012 | 06:05 AM
DRKNGHT's Avatar
So I just need to replace the rubber bushings? Anyone know where these can be found?
Thanks for all the help!
Old Mar 13, 2012 | 11:16 AM
rrrruben's Avatar
I use Pelicanparts. They have nearly every P-car part, and deliver very fast.
http://www.pelicanparts.com/catalog/...Suspension.htm
Old Mar 13, 2012 | 11:25 AM
Pors-Vette's Avatar
Pors-Vette is a jewel in the roughPors-Vette is a jewel in the roughPors-Vette is a jewel in the rough
A friend of mine had a similar noise on his 996 and he replaced the lower ball joint arm as the grommet was brittle and that took care of the problem. But as others have said, it may be your sway bar bracket grommets. Sorry, can't tell you how to get to it though as I'm a newbie Porsche owner. I looked underneath the front end of mine and all I saw was shielding.
Old Mar 13, 2012 | 03:45 PM
GOB's Avatar
GOB
GOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud of
When I used to have my 996 and had the clunking noise, it turned out to be the rubber ends of the droplinks. Not terribly expensive to replace, but annoying as the bad roads here wore them out in no time (once a year!)
Old Mar 14, 2012 | 11:38 AM
WDC 911's Avatar
WDC 911 is infamous around these parts
I have the same issue on the passenger side. I always thought it was my spring or strut that needs replacement.
Old Mar 15, 2012 | 01:41 PM
DRKNGHT's Avatar
had a full inspection today. turns out it is the ball joint on control arm. mechanic suggested replacing control arm and sway links.. That sound about right?
What are my options with those parts?
Old Mar 15, 2012 | 07:41 PM
rrrruben's Avatar
You can pay him now (both ball joints), or you can pay him later (mechanic suggested replacing control arm and sway links). I would opt for the latter, and be done with it.
http://pelicanparts.com/
Old Mar 16, 2012 | 04:23 PM
WDC 911's Avatar
Do you mind sharing the cost? Or is this a DYI + alignment job?
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
orbelo
Aug 30, 2015 12:26 PM
gulf gt
Aug 27, 2015 10:27 AM
