Door window
Old Dec 10, 2012 | 03:45 PM
Pors-Vette's Avatar
Pors-Vette is a jewel in the roughPors-Vette is a jewel in the roughPors-Vette is a jewel in the rough
Door window
This just started today and concerns the drivers door window. There is a "rattling" noise as the window is raised or lowered. When I close the door, and the window is in the up position, the window automatically goes down about 1/3 the way and stops. Has anyone else had this problem? Is it the motor? Also, is the window mechanism similiar to VW's in that it is controlled by a cable? Is this problem a DIY repair or should I take it to the dealership? Thanks for any advice.
Old Dec 10, 2012 | 04:40 PM
Gonzo911's Avatar
Gonzo911 is infamous around these parts
Sounds like a bad window regulator. Common problem but pricey at a dealer. I know there are lots of DIY's on it here and on rennlist. Good luck.
Old Dec 10, 2012 | 04:45 PM
Dennis C's Avatar
This sounds like a window regulator to me too. The regtulator unit has a cable that stretches out over time and eventually fails. It's not too bad from a DIY perspective if you're handy. There is a DIY guide on www.renntech.org, if I'm not mistaken. The hardest part of the whole thing is taking the door panel off without damaging the leather.
Old Dec 11, 2012 | 08:32 AM
ECS Tuning - Porsche's Avatar
We can get you a OE or a aftermarket one and with the DIY given by Dennis C you will be able to get it back in working condition in no time. Click Here to view our selection.
Old Dec 11, 2012 | 10:04 AM
Pors-Vette's Avatar
Thanks everyone for the help. I'm going to take the door panel off today and check it out then decide on a regulator if that's the problem. According to a youtube video on door panel removal it's only a couple of Phillips and Torx screws to remove.
Old Dec 11, 2012 | 07:31 PM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
would you please post that link
thanks !
Old Dec 12, 2012 | 09:40 AM
Pors-Vette's Avatar
thanks !
Ask and ye shall receive!
There is another Phillips head screw behind the inside door handle that the video doesn't mention. If it does I must have missed it.
It took 30 mins to remove the door panel and another 15 to remove the styrofoam insulation cover. Take your time to avoid any scratches or breakage. A friend of mine had a new window regulator which I installed yesterday also. Works like new!
Old Dec 12, 2012 | 11:50 AM
Glad you got it back to working order and thank you posting the video.
Old Dec 14, 2012 | 06:12 PM
properformance1's Avatar
properformance1 is infamous around these parts
Bad window regulator, it happened to me in the past.
NC 996TT
Mar 23, 2023 06:19 AM
ExSF
Bentley
Apr 9, 2017 05:28 AM
Axxlrod
Oct 26, 2015 11:54 AM
kahala997s
Sep 15, 2015 05:15 PM
sparks
Sep 8, 2015 03:03 PM
