about to purchase 2000 911 with nav. want to upgrade to double din..parts needed?
I am about to purchase a 2000 porsche 911 with 55k miles. It has factory nav.
I want to upgrade the strero to a double din. What parts are needed to do the upgrade?
Thank you!!
Thank you!!
There may be more to it than that. Does it have PCM? If so, you will be losing control of those functions. Otherwise wherever you get the new system should have everything you may need (new bezel, wiring harness, possible mounting brackets...).
http://www.ebay.com/itm/99-01-PORSCH...item33842cf315
Is the kit you need.
http://www.salectronics.com/shopdisp...=In%2DDash+GPS is a good source of head units
If you want to add an amp, then the Kenwood XR5S is the same size as the CD changer and fits in the same spot
http://www.salectronics.com/shopexd.asp?id=1528
Lots of blogs and posts on the how to all over the place including here.
They have it wired through the nav system? Also you could always just rip through second gear to turn it off i guess, a bit dumb but works i guess.
Because the PCM/Nav has car function controls that - in the past - were not available on aftermarket parts. Dennis says some new ones have that so I would ask him for specific suggestions on what to use. The only people I see with major electrical or functional problems are those who have changed electrical components on their cars. That's why I leave everything alone and just drive the car. However, if there is a double-din system that will replace all of the PCM functions I too would like to know which one(s) would work. After you change yours, and have no issues for a while, I might consider doing the same in my Carrera. That would be the only way for me to get new mapping.
2lflat4
Nov 18, 2019 05:05 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
Fadi
Aug 21, 2015 03:43 AM
