battery issue?
Old Feb 1, 2014 | 11:09 AM
TrueGuardsRed's Avatar
TrueGuardsRed is infamous around these parts
Question battery issue?
02 BoxsterS: battery is at the point where it will not start the car but all interior lights work...power windows work...hood/trunk release work. Will a 12V battery tender "juice" it up enough to start? Or will I need something else?
Old Feb 2, 2014 | 02:26 PM
911C4S's Avatar
911C4S has a spectacular aura about911C4S has a spectacular aura about911C4S has a spectacular aura about
Is a battery tender like a charger? I say try a charger to see if the battery holds the charge, but if not you'll better off getting a new battery. Had the same issues awhile back and ended up getting a new battery. Good luck
Old Feb 2, 2014 | 08:02 PM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Ok,
A tender is just that, it keeps the battery charged with low monitored charging as not to over charge, a charger does just that, charges and shuts off after full charged is reached, they are not interchangeable.
If the battery is not holding a charge you have a dead cell and it needs to be replaced. In most cases when a battery will not start the car it's on it's last leg, so be done and replace it.
Old Feb 3, 2014 | 04:32 PM
Thanks, I bought a 660a 12V battery booster ($49) and the car started right up. But yes this battery has been in the car for 5 yrs so I would imagine its probably got limited reliable life left in it. This winter in Chicago has been most brutal. When I bring the car in for pre-season service I'll have the battery changed.
Old Feb 4, 2014 | 04:22 AM
Tdurden032's Avatar
Tdurden032 is infamous around these parts
Great info - thanks for sharing!!
Old Feb 6, 2014 | 12:01 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
I would change it before you get stuck somewhere and wished you had.
Old Feb 6, 2014 | 09:29 AM
Currently I do not drive the car in winter...especially this winter in Chicago. I just start the car once a week and let it run for about 15 mins or so. But, I will surely look to replace the battery come Spring time. In the mean time this battery booster is like a battery within a battery. No need for an AV outlet. Just charge the unit up and put it in the trunk. (dimensions: 8x10") No need for jumper cables or another car to help jump the battery. I would recommend one of these to anyone!
Old Feb 7, 2014 | 08:35 AM
jsm996's Avatar
jsm996 is infamous around these parts
Down in the south we don't really have this issue with cars, as the weather is pretty good year round. I do, however, have a boat and jet ski and these are not ridden very often. We actually use Battery Butler and is about half the cost of the Batterytender. We've had good luck with them and they have a decent warranty too. We had a few go bad (we leave these boats covered outside on the dock) due to the elements and they have replaced them at no charge.
Old Feb 7, 2014 | 09:17 AM
02TX996Cab's Avatar
02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold02TX996Cab is a splendid one to behold
Letting the battery run down and then boosting it will reduce the overall life of the battery considerably. A battery tender is definitely the way to go. If you don't have an AC outlet near where you park your car and you truly aren't going to drive it over the winter, one option is to remove the battery and bring it inside to where you have an AC outlet nearby, and then put it onto the tender there.
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
Feelgood MD
Mar 24, 2016 09:35 AM
MMK110464
Sep 2, 2015 06:14 PM
