Clogged drain
Old May 27, 2014 | 06:16 PM
porschemama's Avatar
porschemama is infamous around these partsporschemama is infamous around these parts
Clogged drain
While I was removing my wheels to paint them, I noticed a small leak coming down from one of the wheel wells. I've read about clogged drains being annoying issues on 996s and Turbos so I took peek. Sure enough, it was clogged. For newbies like myself, I've posted pics to help. The red arrows show where the bolts are to uncover the drain. The star is where the drain is located behind the covering.
ID:	379319   Click image for larger version
ID:	379320   Click image for larger version
Old May 27, 2014 | 08:00 PM
lgl314's Avatar
lgl314 is infamous around these parts
Hi Porschemama, The photo looks like a cabriolet like mine. The drain you show is on the pass/side. My PS drain leaked a lot of fluid which I traced to the C-top hydraulic cylinder . . . ended up replacing the cylinder. Might be worth checking . . . I could look at the bottom of the cylinder by simply removing the rear speaker in the side panel. Good luck, have fun . . . Larry
Old Jun 5, 2014 | 07:21 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
on 996T is the same location of drain plugs> I think i have to take off the fender liner
Old Jun 6, 2014 | 08:52 AM
lgl314's Avatar
Madwhip, I'd bet that the rear wheel well drains on the 996T are behind the fender covers just like on my 1999 996 C2 Cab.
Old Jun 6, 2014 | 10:40 AM
Here's a few threads I used to get a quick 411 and get acquainted with my Pcar, with pics:
For your coupe:
http://forums.rennlist.com/rennforums/996-forum/364241-helpful-tip-clean-your-front-drainage-holes.html
For cabs and possibly similar to coupes as well:
http://forums.rennlist.com/rennforums/996-forum/515457-water-in-my-cab-what-to-do.html
http://forums.rennlist.com/rennforums/996-forum/542352-cabrio-water-drains.html
http://www.renntech.org/forums/topic/7791-cautionary-warning-heads-up-for-cab-owners/?hl=cabriolet++drains
Old Jun 6, 2014 | 10:43 AM
Hi Larry, please call me Marie. Sometime I regret choosing that username
Will do, thanks for looking up. Any special tools to get to the rear speakers?
Old Jun 8, 2014 | 05:06 PM
lgl314's Avatar
Hi Marie, The only tool used to remove the speakers is a Torx screwdriver, not sure of the size, #8 or #10. I checked the threads you posted and then checked my P-car. Thanks to your post I found a whole bunch of 'schmutz' (auf deutsch) plugging the front DS drain and the PS rear drain (behind the speaker). Thank you, thank you, thank you . . . your post saved me a whole lot of anguish, time and MONEY! The wife and I had the car out for a 4 hour drive, beautiful, top down weather here in western WI! Larry
Old Jun 9, 2014 | 08:42 AM
No prob, glad to help. I tend to take detailing to a whole new lelvel
Seriously though, I bought this 10 year old car with my eyes wide open, knowing and budgeting an amount of work or schmutz to be done. I'm all for saving money too-- already saved $100k by skipping the 991 and getting the same thrill. Glad you two are enjoying some quality time together!
mmdht2
Cayenne 958
Mar 29, 2016 12:33 PM
ECS Tuning - VW
Sep 30, 2015 12:21 PM
ECS Tuning - BMW
Sep 23, 2015 01:31 PM
ECS Tuning - BMW
Sep 22, 2015 08:34 AM
ECS Tuning - BMW
Sep 11, 2015 09:02 AM
