Serious electrical problem. Huge battery drain parked
Old Nov 25, 2018 | 10:15 AM
swampyankee's Avatar
swampyankee is infamous around these parts
If I don't pull the 7.5 amp fuse for the radio circuit a fully charged new oe Porsche battery will drain down to 0 volts within 2-3 days not being used.
The immobilizer and ecu was pulled and sent out for test. Both tested good.
All 5 wired switches work.
was told problem is somewhere else .
I work on vehicles of all sorts since I was 11 and I'm 68 now. I purchased 996 repair manual on line at first.
got me stumped. Car is worthless as is at 45k miles.Purchased car at Barrett Jackson auction 6/18. Was listed as having no known problems. Car had to be jumped by service crew and had to have gas added to it when I picked it up! Boy did I get screwed. Could not flip it. Got stuck with it.
Any ideas?
Old Nov 25, 2018 | 07:15 PM
ZuffenZeus's Avatar
ZuffenZeus is infamous around these parts
Any ideas?
I wouldn't throw in the towel over a battery drain issue. Pretty minor compared to the "real" problem that occur with these cars.
Parasitic battery drain is not totally uncommon with these cars. Tell us more about the car - what year? what radio system? CDR-220, CDR-23, PCM??? Frunk amp?
Old Nov 28, 2018 | 12:56 PM
'99 Carrera 996 cabriolet 45 k miles. I already know about the intermediate shaft bearing. It has the standard issue becker radio an CD changer
Old Nov 28, 2018 | 01:29 PM
ZuffenZeus's Avatar
Does it have the amplifier in the frunk? Are we talking about the double DIN PCM radio or single DIN. What's the model number of radio?
By the process of elimination, I would rule out the radio and amp.
1. reconnect the fuse
2. Disconnect the radio and amp
3. check battery drain with a multimeter
If it's still pulling current, then you know it's something else in the mix.
Old Nov 29, 2018 | 02:28 PM
wyovino's Avatar
wyovino is a jewel in the roughwyovino is a jewel in the roughwyovino is a jewel in the rough
Agreed. Eliminate the radio, amp, and CD changer as possible causes first. The radio has a wire to turn on the amp. Since you don't know the history, it's possible that someone messed around with the set up and the amp and/or changer is always powered on. That's where I would start.
Old Nov 29, 2018 | 09:07 PM
malibu711's Avatar
malibu711 is infamous around these parts
I bought my 996 TT at Barrett Jackson in September and have the same problem, among many other issues. I feel your pain.
Old Nov 30, 2018 | 07:56 AM
ZuffenZeus's Avatar
Have you located the source of parasitic power drain?
Old Nov 30, 2018 | 09:42 AM
malibu711's Avatar
Right now there are other stuff that make it undrivable, so I have not started on that issue. Cracked rim, transmission problems, ignition switch, etc.
I am following this thread and will update when I get to that point.
TBH this isn't the only car I got at Barrett Jackson that was a turd. Two more I have are equally if not more dysfunctional. I don't see how they can still be around letting people burn buyers like this.
Old Nov 30, 2018 | 09:54 AM
ZuffenZeus's Avatar
Auto auctions (and maybe Carmax) are the worst places to buy these kinds of cars, IMHO. Why is that? Lots of dealers dump their lemons on auctions and pass the problems onto the buyers. Most of the auctions don't let you conduct a thorough inspection. In many auctions, you can't even get in the car and start it. Unless you have a skilled set of mechanics/techs on hand, I wouldn't advise going to an auction to buy Porsches. I would rather buy them on craigslist from the owners.
Old Nov 30, 2018 | 12:49 PM
wyovino's Avatar
Ignition switches are known to cause all sorts of weird electrical issues with these cars. That might be a good place to start. (no pun intended)
Old Nov 30, 2018 | 12:53 PM
ZuffenZeus's Avatar
bwhahahahahaha!!!!!!
Old Nov 30, 2018 | 01:42 PM
malibu711's Avatar
Hahahaha.. Yes I read that as well. It is on the list.
As far as buying from the auction, it is Barrett Jackson, so its not like we are going down the street to the local used car auction. You expect there to be some type of level of quality. Buyer beware!
Thklinge
Nov 28, 2018 01:00 PM
n6pvj
Aug 12, 2016 10:12 AM
elitejic
Maserati
Mar 8, 2016 04:06 AM
raidentech
Sep 20, 2011 12:02 PM
F1 Kevin
Jul 29, 2011 10:40 AM
