Problem with 1st gear!!
Old Dec 10, 2006 | 12:09 PM
SD996's Avatar
SD996 is infamous around these parts
I've been having some problems with my first gear. Occasionally when I try to put the gear in first (while stopped) it does not engage properly and I have to double or triple clutch to get it in. Has anyone had such a problem before? Could it be the clutch? I only have 25k on the car (03 996). I also don’t have a short shifter……
Old Dec 10, 2006 | 02:25 PM
John Romano's Avatar
John Romano is infamous around these parts
Same thing happens to me once in awhile. I just bought the B&M shifter. When I put it in I'm ging to use the P-Tool to check the cables and then see if the shifter helps. Everyone tells me it will.
Old Dec 10, 2006 | 04:27 PM
Redridge's Avatar
Some of these tranny has issues going into 1st/2nd when its cold.
Old Dec 12, 2006 | 02:09 PM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
Always a little hard to shift in the cold, hope you're not trying to down-shift into 1st.....
-Eli
Old Dec 12, 2006 | 02:15 PM
ZX9RCAM's Avatar
ZX9RCAM is infamous around these parts
-Eli
Sometimes MORE than a little, lol.......
Old Dec 12, 2006 | 05:03 PM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
Mine has the same problem SD996
It won't go into 1st sometimes and feels like it's hitting a wall and will break if I push it.
Have you had a RMS issue with the car?
Mine was fine until my 2nd RMS.
When I picked the car up from service, I couldn't get it into first.
They 'checked ' the cables, etc. and couldn't find anything.
After living with it for a while, I complained to Porsche and got a call from the zone 'Rep' who insulted me by telling me "you've got some big gears in there and it can happen, blah blah, blah.
I'm still living with it.
Old Dec 12, 2006 | 05:35 PM
ZEMDOGG's Avatar
ZEMDOGG is infamous around these parts
Well this post is a sign of releif! I have the same problems. The most annoying thing is when it dosent engage in second and you grind it!
Old Dec 12, 2006 | 06:03 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
If you are grinding into any gear, that is not normal, no matter how many other people it happens to. Also, if the linkage is adjusted properly and the tranny is working as it should, you can shift quite easily into first gear at any speed less than 30 mph.
Old Dec 12, 2006 | 06:07 PM
ZEMDOGG's Avatar
I think its my fault though. When the car isnt warmed up in the morning and I think its in second I touch teh shifter on accident without engaging the clutch thinking its already in (it should be). Then I get a slight grind. If its warmed up and im not a dumbass it goes in but stiff.
Old Dec 13, 2006 | 12:43 PM
SD996's Avatar
Thanks for all the info. This only happens in first gear and when the car is stopped and it doesn't make a difference if the car is cold or warm. It think I'll take it to the dealer to take a look.
Old Dec 13, 2006 | 12:55 PM
ZX9RCAM's Avatar
If it happens when the tranny is FULLY warmed up, then there is
some underlying problem....
georgemaser
Oct 17, 2015 05:59 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
GSP
Sep 9, 2015 05:31 AM
andbos
Sep 7, 2015 07:13 PM
Saint Ari
Sep 4, 2015 03:30 PM
