Help Car Wont Start!!!!!!
Old Sep 12, 2007 | 10:07 AM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
Turns over like normal, just doesnt start. Was running perfect last night....any ideas? I checked the fuel pump fuses and they were ok....have a half a tank of gas so its got gas...ideas? But it just turns over like its out of gas....would the fuel pump just let go like that? No warning? Anything that I can check???? HELP??????
Old Sep 12, 2007 | 12:09 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
To elimnate fuel as the cause, remove a vacuum line from near rhe throttlebody and spray some starter fluid in it. If you get a sputter, then suspect a fueling problem. You might also reset the computer by disconnecting the batery to see if this corrects any fault.
Old Sep 12, 2007 | 12:13 PM
newport996's Avatar
Update....sprayed brake cleaner into the throttle body..car started then died...ugh...so i suspect its a fueling issue, fuel pump, regulator, etc...so they will check it at the indy....its on its way there now.
Old Sep 12, 2007 | 01:04 PM
ZEMDOGG's Avatar
ZEMDOGG is infamous around these parts
Dman, that sucks! I vote for fuel problem. Not sure what it could be.....oh wait i work at the dealer let me go check ; ) Back at you in a few!
Old Sep 12, 2007 | 01:21 PM
ZEMDOGG's Avatar
Talked to our tech over here. Sayes what usually happens is the fuel gauge breaks and you run out without knowing. Sounds silly but it may be worth it to add a couple of gallons of gas. Sorry but thats all I got : (
Old Sep 12, 2007 | 01:25 PM
newport996's Avatar
Not silly at all....its what it sounds like.....and maybe I should have had tha AAA guy bring a gallon to verify.....but there was plenty of gas in the tank.......
Old Sep 12, 2007 | 03:57 PM
newport996's Avatar
update: Its the fuel pump...the great people at Hergesheimers are fixing it now....
Old Sep 12, 2007 | 04:24 PM
ZEMDOGG's Avatar
Well thats good! Err bad err I mean could be worse : ) Good luck!!!
Old Sep 13, 2007 | 12:09 AM
dhrecon's Avatar
dhrecon is infamous around these parts
Hey Newport, i have been looking for a good indy in the OC. Where is Hergesheimers located and are they fair with pricing? I live in Brea. Thanks. Dean
Old Sep 13, 2007 | 10:37 AM
daytrader's Avatar
daytrader is infamous around these parts
Owner Mark & wifey are terrific people to work on your car. I live in Central O.C but don't mind driving 20+ miles to Hergesheimers for maintenance.
Be careful not to chat with Mark about speeding on the road. He's a O.C Sheriff.
Old Sep 13, 2007 | 01:43 PM
newport996's Avatar
Great guys, really know the cars and they look out for you....I have a cracked lip spoiler and they thought the tow truck driver did the damage, they took pics, emailed them to me and documented the whole deal "just in case" it was the tow truck drivers fault....just talked to them about fuel gauge calibration after the repair was done...very thorough in their repairs...
Old Sep 13, 2007 | 02:57 PM
demosan's Avatar
demosan is infamous around these parts
They are located is Lake Forrest. I had them do a PPI on a Pcar I bought in OC and they are great folks to work with. I wish they were closer to San Diego as I would use them regularly.
Demosan
Old Sep 13, 2007 | 04:21 PM
newport996's Avatar
Just got the car back....they are very good guys...the car is running better than ever! I wonder if I was losing fuel pressure for a while and not noticing it...Ithe car seems alot peppier then I remember.....
Old Sep 13, 2007 | 04:26 PM
Redridge's Avatar
...good, you dont have to get that lexus now. Enjoy the new power
Old Sep 13, 2007 | 08:38 PM
newport996's Avatar
LOL...nope and she hasnt mentioned it once!
pwdrhound
Sep 16, 2021 02:27 PM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
vr6tee
Aug 29, 2015 03:52 AM
gulf gt
Aug 27, 2015 10:27 AM
DSCOFF
Aug 23, 2015 01:22 PM
