Boost gauge?
Old Oct 3, 2007 | 07:27 PM
MKS's Avatar
MKS
MKS is a glorious beacon of lightMKS is a glorious beacon of lightMKS is a glorious beacon of lightMKS is a glorious beacon of lightMKS is a glorious beacon of light
Boost gauge?
How much bar are you guys seeing? with the sport mode? flashed or not?
i have a flash and seeing only 1 to 1.1 with the sport mode is that normal? and .9bar in second and third
car is a tipronic!
Old Oct 3, 2007 | 08:02 PM
neosky's Avatar
neosky is infamous around these parts
If your car is chipped, what brand did you go with? My car is also a tiptronic, but I have only seen 1 bar in normal mode and 1.2 bar from 4000rpm all the way to the redline in every single gear. My car is chipped by the Swiss tuning company ChipTronic, but I'm sure GIAC and other reputable tuners also get 1.2 bar fully as well.
You should get your car checked/reflashed again.
Old Oct 3, 2007 | 09:57 PM
MeanMachine's Avatar
Try using 100 octane unleaded fuel, the green coloured one at the petrol station.
Old Oct 4, 2007 | 03:56 AM
haudimal's Avatar
haudimal is infamous around these parts
not chipped, with overboost up to 1,2 at around 4000rpm, down to 0,9 at rev limiter.
I think it depends a little bit on the temperature, sometimes it is not going up to 1,2bar
Old Oct 4, 2007 | 03:58 AM
IIVVX's Avatar
IIVVX is infamous around these partsIIVVX is infamous around these parts
you guys get 100 at the station? niiice
Old Oct 4, 2007 | 04:06 AM
neosky's Avatar
LOL! I'm sure they have all types of "exotic" gasoline over there. Maybe I will trade them some Evians for some Octane 100 gas!
Old Oct 4, 2007 | 05:24 AM
mishref's Avatar
mishref is infamous around these parts
Our green gas is 98 RON which is the same as US 93 Octane ((RON+MON)/2). Just a heads up in case you thinking about raising the boost or chipping a car.
The most common type of octane rating worldwide is the Research Octane Number (RON). RON is determined by running the fuel in a test engine with a variable compression ratio under controlled conditions, and comparing these results with those for mixtures of isooctane and n-heptane.
There is another type of octane rating, called Motor Octane Number (MON) or the aviation lean octane rating, which is a better measure of how the fuel behaves when under load. MON testing uses a similar test engine to that used in RON testing, but with a preheated fuel mixture, a higher engine speed, and variable ignition timing to further stress the fuel's knock resistance. Depending on the composition of the fuel, the MON of a modern gasoline will be about 8 to 10 points lower than the RON. Normally fuel specifications require both a minimum RON and a minimum MON.
In most countries (including all of Europe and Australia) the "headline" octane that would be shown on the pump is the RON, but in the United States, Canada and some other countries the headline number is the average of the RON and the MON, sometimes called the Anti-Knock Index (AKI), Road Octane Number (RdON), Pump Octane Number (PON), or (R+M)/2. Because of the 8 to 10 point difference noted above, this means that the octane in the United States will be about 4 to 5 points lower than the same fuel elsewhere: 87 octane fuel, the "regular" gasoline in the US and Canada, would be 91-92 in Europe. However most European pumps deliver 95 (RON) as "regular", equivalent to 90-91 US (R+M)/2, and even deliver 98 (RON) or 100 (RON).
Old Oct 4, 2007 | 09:52 AM
Thank you for correcting me, easy explination.
Old Oct 4, 2007 | 09:53 AM
TT Surgeon's Avatar
1.2 bar in sport, 1.0 regular.
Old Oct 4, 2007 | 09:57 AM
MKS's Avatar
MKS
ill try again tonight and see what happens and thanks guys for the help
Emre@Esmotor
Oct 19, 2015 12:06 PM
whtrabt
Oct 5, 2015 05:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
