Oil Change
Old Mar 13, 2008 | 11:39 AM
ERSKATEDOC's Avatar
ERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to behold
Oil Change
For my new 997, how often should I get the oil changed? Yearly seems a bit too long, especially the way I drive!!!
Old Mar 13, 2008 | 11:52 AM
lager99's Avatar
lager99 is infamous around these parts
Car says 30,000kms...dealer told me every spring is fine.
Old Mar 13, 2008 | 05:39 PM
gradyex's Avatar
gradyex is infamous around these partsgradyex is infamous around these parts
I changed mine at 1000 miles and every 5000 miles or 1 year which ever comes first. I like to do it because its easy and I know the job will be done right. A straight 997 is so simple I didn't even have to jack up the car. I bought a set of Speed Ramps for the turbo (you don't need the standard size for oil changes, use the mini ramp instead and do it on a level surface). The car is supposed to be at operating temp so be careful and wear protective gloves. The exhaust system will be hot too! The turbo is a bit more involved. Go to rennteam for the details and torque settings for the different bolts + oil filter. If your not into getting your hands dirty (nothing wrong with that) ONLY have your Porsche dealer do it.
Old Mar 13, 2008 | 06:55 PM
Porsche997TT's Avatar
Porsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to behold
Same Here....Changed oil around 1k miles. I'll be changing it at least once a year. if your car sits for long periods of time it needs to be changed more often. Becuase your TBN will drop.
I'll be doing a UOA on my M1 0W-40 soon to ge tan idea how long I should run my oil.
Old Mar 14, 2008 | 06:22 AM
benVTGizzle's Avatar
benVTGizzle is infamous around these partsbenVTGizzle is infamous around these parts
If you daily drive your car how often should you change the oil? The dealership told me to change it at 22,000 miles, which I thought was kind of odd. I've had to add oil around every 3,000 miles after the oil level drops. This is natural right?
Old Mar 14, 2008 | 02:14 PM
Yea it's normal...The right way to do those Long Oil Change Intervals is to do "Used Oil Analysis" All you do is buy a Kit from Blackstone Labs and you send them back a small sample of your oil and they run a couple of different tests. And they give you back a spec sheet telling you hows your engine doing.
Blackstone-Labs.com
Bobistheoilguy.com
Are both excellent website's on keeping your Porsche running up to spec.
Old Mar 14, 2008 | 04:01 PM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
We recommend that the oil be changed every 4-5k during normal use.
If you are doing track days I would recommend every other weekend.
Oil is a cheap way to ensure long term engine life.........
I saw that your in Newport we do regular maintenance and service work.
Feel free to stop by the shop at anytime.
Old Mar 14, 2008 | 04:21 PM
...................+1 Oil is cheap Engine's Aren't
Old Mar 14, 2008 | 06:13 PM
Texas911's Avatar
Texas911 is infamous around these parts
Anyone know if we can use a suction device to change the oil?
alwaysbored786
Apr 19, 2016 05:51 AM
4ocious
Sep 1, 2015 06:44 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
