Exhaust or ECU upgrade?
Old Nov 7, 2008 | 01:35 PM
  #31
ChadC's Avatar
ChadC is infamous around these parts
Just put the Fabspeed on my cab this week. It sounds GREAT! Not as noticable of power change as the ECU though. Both are great mods. Have fun.
Old Nov 7, 2008 | 10:26 PM
  #32
2008911tt's Avatar
2008911tt is infamous around these parts
Originally Posted by TTdude
A week--I like your optimism. Let me know how you like the exhaust, especially if there are any bad drones. Other threads have reported this prblm with Fabspeed.
I got a dry day today and took the car out for a spin. It sounds good but there is a bit of a drone between 2200 and 2700-2800 rpms. It is tolerable with windows up or down. Very throaty exhaust at low rpms and quieter at higher revs. Ran into a boost problem that I need to solve. I am only getting about 7 psi before the turbos blow off.
Old Nov 8, 2008 | 01:12 AM
  #33
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
I assume your exhaust is FS 3rd generation? Sorry to hear about your boost problem. Did you contact FS? They're usually very helpful. Repost as a separate thread. Your bound to get some suggestions. Best wishes.
Old Nov 8, 2008 | 10:01 AM
  #34
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
Are you saying you are only getting 7 psi boost? That is very low, switch over to Bar and get that number too. You must have a loose boost hose or something. I would go over the entire install and double dog check everything.
Old Nov 8, 2008 | 04:07 PM
  #35
TT Surgeon's Avatar
I think he changed the intake too, I'd check that for sure. Sounds like a leak on the intake side of the system.
Also check the clamps btwn the cats and the rest of the system, those will loosen on FS and drone. You'll need to switch to oem 996 c4s clamps to solve the problem.
C
Old Nov 10, 2008 | 10:51 PM
  #36
2008911tt's Avatar
C
TT Surgeon and everyone else. I removed and reinstalled the intake system. That solved the boost problem. I am not sure where the leak was because all the clamps were tight but I suspect it was at the rubber boot where the Y pipe connects to the throttle body. As you know the clearances at this joint on the bottom are tight and it may have been that the rubber boot was not properly alighed on the bottom of the Y pipe. The Y also connects at a slight angle. I took extra care in reinstalling this connection.
Thanks to everyone for ideas and suggestions. Special thanks to TT Surgeon who helped me with a number of facets related to the mods.
Old Nov 23, 2008 | 08:11 AM
  #37
Kafka997's Avatar
Kafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond repute
THE one mod!
http://www.bilstein.de/cms_website/e...ideos/Movie_4/
While this is a BMW, I think this video captures the thrill of driving that comes with upgraded suspension. Exhaust or suspension first, ECU later (TT already has good power)
K.
P.S. This video =
Old Nov 23, 2008 | 08:29 AM
  #38
sbkim's Avatar
sbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond repute
Any chance you can do the ECU and revert back to stock before taking to the dealer? Or can the tech scan and eventually find out?
Old Nov 23, 2008 | 09:12 AM
  #39
sbkim's Avatar
Also who offers the lowest priced exhaust system? AWE? Anyone try the muffler replacement system?
Old Nov 23, 2008 | 10:20 AM
  #40
bbywu's Avatar
You really need to do a search. This has been beat so far to death, that the carcass is begging for mercy.
https://www.6speedonline.com/forums/...od-issues.html
https://www.6speedonline.com/forums/...-your-dme.html
https://www.6speedonline.com/forums/...rket-mods.html
https://www.6speedonline.com/forums/...tt-thread.html
Old Nov 23, 2008 | 10:21 AM
  #41
bbywu's Avatar
see above, and
https://www.6speedonline.com/forums/...pressions.html
Old Nov 23, 2008 | 10:49 AM
  #42
sbkim's Avatar
Originally Posted by bbywu
My bad - thanks for the links!
Old Nov 24, 2008 | 01:08 AM
  #43
TTdude's Avatar
I wonder what the guy is like when he is really excited?
K.
P.S. This video =
Old Nov 29, 2008 | 10:05 PM
  #44
AutoTalent2's Avatar
AutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to all
IMHO, Exhaust first, you can hear it, touch it & feel it (the power). It will change up the characteristics when you drive more than the chip alone. Chip should be done close to last as it will bring everything together, the MC.
Old Nov 29, 2008 | 10:18 PM
  #45
Neeeenja's Avatar
Neeeenja is a jewel in the roughNeeeenja is a jewel in the roughNeeeenja is a jewel in the rough
Exhaust, only after a year or so should one consider the ECU since you wouldnt really know what the improvement was and be more satisfied.
Jul 29, 2019 11:13 AM
Sep 14, 2015 06:42 PM
Superaudiofreak
Sep 4, 2015 03:22 PM
Sep 1, 2015 03:16 PM
Aug 20, 2015 12:17 PM
