Bilstein B16 Damptronics Drop (aka WEAK) Links
Old Mar 19, 2010 | 09:31 AM
  #61
bbywu's Avatar
Originally Posted by mact3333
I love the debates on here but somnetimes I wonder if Im at a AMA medical meeting rather than 6 speed as gas passers and surgeons square off, just like in the OR....
But Can., at least the surgeons cant boss ya round on 6 speed huh?...
Don't make me beat you with my EEA stapler.
Old Mar 19, 2010 | 09:33 AM
  #62
bbywu's Avatar
Originally Posted by cannga
TT Surgeon, your memory might be off: it was NOT. I believe yours was installed on the wrong side -- inboard. You posted some pictures and I saw them at the time but since it was professionally prepped by such a big company I didn't feel like commenting; didn't think it would cause any problem until eclou pointed it out. (I do have good memory when it comes to anything Bilstein on 6speed. )
Bob, I do believe that eclou is right again. See above -- even the biggest of them, Farnbacher Loles or not, may make mistake. I assume yours is outboard like eclou's, Alex's, and mine? So far we have at least 2 that pop, sparkhill's and TT Surgeon's, that are both inboard.
Can, at this point, I am so frick'n confused by this that I honestly can't remember! lol...
And I've learned in the time that I've been here...Gene is usually right.
Old Mar 19, 2010 | 03:12 PM
  #63
cannga's Avatar
LOL. 6speed = the great equalizer and the only place where room turnover time doesn't matter.
Bob, yes, when I look back at old posts, remarkably "eclou" is usually right, AND a couple of years ahead of everyone else.
Old Mar 19, 2010 | 03:18 PM
  #64
cannga's Avatar
Sure, they are meant to be adjusted. Re. memory, I have my own to worry about, so you have to keep track of your own accuracy!
Originally Posted by TT Surgeon
No, they were outboard, after that pic I adjusted them at the track, the only way I could get full stiff was going outboard. They were initially inboard, as per bilstein instructions, but for less than a week.
I don't know about you, but at the track I'm constantly adjusting my sways. But, thanks for keeping an eye on me....and my memory. I admit I forgot to check in with the board when I adjusted my sways, won't happen again I promise
Old Mar 19, 2010 | 03:31 PM
  #65
cannga's Avatar
Originally Posted by tranman329
I just had mine redone today when they installed my front RSS sway bar. Has anyone installed the Tarret drop link on the rear and been able to go with the stiffest setting on the sways? My installer say he couldn't get the stiffest setting with the Tarret drop links. With my factory drop links i was able to.
The Tarett link fine should work fine with the stiff setting, at least with GMG and GT3 sway bar. If you truly want to try, come and look with the installer while the car is on the lift and see exactly why it can't be -- we've learned that even the best installer like Farnbacher Loles needs supervision! Call Tarett afterwards and ask for suggestion, they'll send you different washers if needed -- Tarett has near 100% "customer happiness" rating for a reason.
See picture below, the Tarett comes with different thicknesses for the cone washers, and by using different combination/position, and different thickness of cone washers, you should be able to connect with an excellent straight "line." My tuner did. Remember: All connections are not the same, you want the straightest line, and the activation/contact point to be as close to the target as possible to prevent bending (in the example below, the thick cone washer pushes the contact point outwards needlessly and was subsequently replaced).
One word of warning based on my **limited** experience so far (anyone corrects as needed): The 997 does **NOT** seem to like increased stiffness in the rear, be it stiff sway or real stiff spring. Another person on rennteam and I are probably the first 2 to play around with this on 997 Turbo, and independently, we came to the conclusion that stiff setting of rear sway, especially with metallic joint drop link like Tarett, etc., makes car unusually bouncy and uncomfortable for daily drives. So we both left the rear at medium, and front at either soft or medium.
Old Mar 19, 2010 | 07:14 PM
  #66
dk10438's Avatar
dk10438 is a splendid one to beholddk10438 is a splendid one to beholddk10438 is a splendid one to beholddk10438 is a splendid one to beholddk10438 is a splendid one to beholddk10438 is a splendid one to beholddk10438 is a splendid one to behold
oh gawd, another one! i'd be careful though, mac might be forced to retaliate with his big X-ray gun! I'm glad to see that we've all finally learn to play in the sandbox together.
Old Mar 26, 2010 | 12:04 AM
  #67
C4SxM5's Avatar
C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !
After confirmation that my installer forgot to install the all so important OEM "washers", I decided to pull the wheels off and see if the my drop links were installed correctly... To be honest I still am not certain after looking at the posted pics & diagrams posted so I went ahead and made a short video with my iphone in hopes the experts here can tell me if they are or if I need to take the car back once again.
I also still hear a popping sound while driving up the driveway with the steering wheel turned all the way so just a bit paranoid. And maybe a dumb question, but are the coils normally loose like this when the wheels are off
Old Mar 26, 2010 | 12:36 AM
  #68
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
your dlinks are installed incorrectly to the sway bar. They should be on the outer end(closer to the wheel) of the sway bar. The noise you hear may be the sways hitting the control arm when the steering wheel is in the locked position(turned all the way to the right or left).
Once you correct this, the noise should be gone.
Old Mar 26, 2010 | 07:58 AM
  #69
bbywu's Avatar
The arrow points to what Neil is talking about...it should be on the other side.
Old Mar 26, 2010 | 07:59 AM
  #70
bbywu's Avatar
Alex, did you know this screw is loose? Or was the photo taken during your setup/install?
Old Mar 26, 2010 | 09:13 AM
  #71
E55AMG's Avatar
E55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud of
WTF? is this such a difficult install that so many shops are getting this wrong?
Old Mar 26, 2010 | 09:43 AM
  #72
cannga's Avatar
LOL & thanks for the chuckle. Installation errors occur across ALL components, be it ECU, suspension, or exhaust. Sometimes the error is not even error, as we are mixing and matching components not anticipated by the manufacturers and no one could cover all the possibilities. This forum is somewhat suspension-aware and Bilstein centric; that's why we are dissecting all issues to minute details and have become knowledgeable, and that's why we are here so much. "Problems" is the price you pay for modding your car, and we keep doing it despite of the risk because this is the only way any car could then become "perfect." :-) This is true for all 911; the guys on GT3 or GT2 forum mod theirs just as much.
If you look enough, there will be "stories" with Motron, JRZ, KW, with exhaust, with ECU tune. You will hear about exhaust tip that flies of, ECU tune that got screwed up, hardware that's not tightened causing disaster.
Moral of the story: Use the best and most experienced installer, educate yourself by staying on on 6speed so you could double check your best and most experienced tuner if/when necessary. People -- me, you, our installer -- are liable to make mistake once in a while in our lives, unfortunately.
Old Mar 26, 2010 | 10:24 AM
  #73
C4SxM5's Avatar
So basically driver side needs to be swapped with passenger side? Or does it need to flip upside down?
Just want to get my facts straight before I call the installer again
Old Mar 26, 2010 | 11:22 AM
  #74
NeilM's Avatar
C4 - just call me to discuss. 650-743-8866
Old Mar 26, 2010 | 11:38 AM
  #75
FastrTHNu's Avatar
FastrTHNu is infamous around these parts
Just in reply to the original post. (didnt read all the details)
But.....
i just had custom, billet aluminum links made. Adjustable on either side, top and bottom, stronger then it ever needs to be, slight bend/kink to allow for ZERO interference with ANY simple little thing you can think of....
ill snap some pic sooner then later.
on a side note, the B16s are 'OK' at the very best. High speed (125+) turns/banking/sweepers NO MATTER what i try. the rear of the car is NOT planted. I blame this on the valving, that is involved with this damptronic, in my opinion, junk.
If its going to the track, its going on a trailer (99.9% of the time)... why not JRZ or Moton that suka?
/rant
